Discuss
Frig & Freezer not cold enough
 in
Refrigerator & Freezer Repair
I purchased a rarely used side-by-side nearly 3-yrs ago when we moved into our rental home, from
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Frig & Freezer not cold enough
  #1 (permalink)
Old 08-14-2007, 03:15 PM
BRIDGETSTEPP BRIDGETSTEPP is offline
Junior Member
BRIDGETSTEPP is on a distinguished road
Exclamation Frig & Freezer not cold enough
Model Number: ED5CHQXKQ01   Brand: Whirlpool   Age: 1 - 5 years
I purchased a rarely used side-by-side nearly 3-yrs ago when we moved into our rental home, from the previous owners. It worked fantastic until the end of April. The icemaker stopped working and then the freezer stopped freezing. For the past few months we have been using the freezer side as our refrigerator. I really need some help & don't have the $200-$600 for a repair man or, even worse, a new refrigerator.
So far I have:
1) Checked temp setting.
freezer setting 1/2 way & frig setting at max.
2) Made enough room for air flow in frig & freezer.
3) Checked & cleaned vents in frig & freezer.
4) Tested the temp controls.
multitester same reading on warmest & coldest settings...is this correct?
5) Cleaned the condensor coils.
Done once at the end of April & about a month later (never cleaned?)
6) Checked the door seals.
7) Tested the door switches.
8) Checked for clogged drain tube.
9) Compressor & condensor fans appear to be working & cycle on & off.
10) Did not notice a refrigerant leak.
11) No ice build up or water in the bottom of the freezer.
From what I have read on several internet sites, I have checked nearly everything except for the compressor relay. We have a lot of brown & black outs in Southern CA & one repair man, over the phone, told me that the relay could be bad or freon needed to be charged. Could this be my problem or the temp controls, since I am receiving the same readings?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer fine, refrigerator not cold fargnoli Refrigerator & Freezer Repair 0 08-08-2007 10:24 PM
Moving a Frig luckiestarrr Refrigerator & Freezer Repair 1 08-02-2007 08:55 PM
Frig gets cool but won't get colder 97SS Refrigerator & Freezer Repair 6 08-01-2007 10:37 PM
Refrig works but freezer is not running cold enough Bill Tagatz Refrigerator & Freezer Repair 1 08-01-2007 06:43 AM
Freezer no longer cold enough clowder64 Refrigerator & Freezer Repair 1 07-25-2007 04:21 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
