I have had a rotting smell coming from fridge for several weeks. Went through fridge few times and found nothing. 1-12-14 Removed cover on back of fridge found two mouse remains. cleaned out under fridge as much as possible. 1-15-14 Ice started to melt through dispenser 1-16-14 All ice melted water all over floor and food thawed Found compressor fan unplugged plug it in compressor fan is now cycling on off compressor is hot Test leads on compressor from another forum readings are within specs
