My Kenmore Coldspot 10651214100 tray evaporator keeps overfilling and flooding my floor. The ice maker took a dive over a year ago so I capped the water line and flushed all remaining water out of the unit; so there hasn't been a water line in for over a year (I used this info to rule out a water filter/water filter housing leak). I'm using a turkey baster and removing 1/2 gallon of clean water daily from the tray but I can't figure out why /where the water is coming from. I haven't had any frost overs, my fans all seam to be moving freely and cycle on/off when defrost cycle runs and I have no blocked-frozen-clogged lines that I have been able to detect. Please point me in the right direction. Thank you.
