Discuss
freezer&refridgs
 in
Refrigerator & Freezer Repair
looking for some help made some repairs still freezing up in freezer Related ModelsAmana ARS2667BC Ref - SXS/I&
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » freezer&refridgs
  #1 (permalink)
Old 10-16-2009, 04:11 PM
dino55 dino55 is offline
Junior Member
dino55 is on a distinguished road
Default freezer&refridgs
Model Number: ars2667bc   Brand: Amana   Age: 5 - 10 years
Related Models
Amana ARS2667BC Ref - SXS/I&W
Amana ARS2667BS Ref - SXS/I&W
Amana ARS2667BW Ref - SXS/I&W
Amana ARS266KBB Ref - SXS/I&W
Amana ARS266KBC Ref - SXS/I&W
Amana ARS266KBW Ref - SXS/I&W
Amana ARS266RBB Ref - SXS/I&W
Amana ARS266RBC Ref - SXS/I&W
Amana ARS266RBW Ref - SXS/I&W
Amana ARS266XAW Ref - SXS/I&W
Amana ARS266ZBB  Ref - SXS/I&W
Amana ARS266ZBC  Ref - SXS/I&W
Amana ARS266ZBS  Ref - SXS/I&W
Amana ARS266ZBW  Ref - SXS/I&W
Amana ARS2760BW Ref - SXS/I&W
Amana ARS635 Range - S/c S/i Ddraft Ele
Amana ARS635W Range - S/c S/i Ddraft Ele
Amana ARS636E Range - S/c S/i Ddraft Ele
Amana ARS636WW Range - S/c S/i Ddraft Ele
Amana ARS8265BB  Ref - SXS/I&W
Amana ARS8265BC  Ref - SXS/I&W
Amana ARS8265BS  Ref - SXS/I&W
Amana ARS8265BW  Ref - SXS/I&W
Amana ARS8267BB  Ref - SXS/I&W
Amana ARS8267BC  Ref - SXS/I&W
Amana ARS8267BS  Ref - SXS/I&W
Amana ARS8267BW  Ref - SXS/I&W
Amana ARS9107AS Ref - SXS/I&W
Amana ARS9107AW Ref - SXS/I&W
Amana ARS9167AB Ref - SXS/I&W
Amana ARS9167AC Ref - SXS/I&W
Amana ARS9167AS Ref - SXS/I&W
Amana ARS9167AW Ref - SXS/I&W
Amana ARS9168AB Ref - SXS/I&W
Amana ARS9168AC Ref - SXS/I&W
Amana ARS9168AS Ref - SXS/I&W
Amana ARS9168AW Ref - SXS/I&W
Amana ARS9169AS Ref - SXS/I&W
Amana ARS9265BB  Ref - SXS/I&W
Amana ARS9265BC  Ref - SXS/I&W
Amana ARS9265BW  Ref - SXS/I&W
Amana ARS9266BS  Ref - SXS/I&W
Amana ARS9268BB  Ref - SXS/I&W
Amana ARS9268BC  Ref - SXS/I&W
Amana ARS9268BW  Ref - SXS/I&W
Amana ARS9269BS  Ref - SXS/I&W
Amana ARSE664BB Ref - SXS/I&W
Amana ARSE664BC Ref - SXS/I&W
Amana ARSE664BS Ref - SXS/I&W
Amana ARSE664BW Ref - SXS/I&W
Amana ARSE665BB  Ref - SXS/I&W
Amana ARSE665BC  Ref - SXS/I&W
Amana ARSE665BS  Ref - SXS/I&W
Amana ARSE665BW  Ref - SXS/I&W
Amana ARSE667BB Ref - SXS/I&W
Amana ARSE667BC Ref - SXS/I&W
Amana ARSE667BS Ref - SXS/I&W
Amana ARSE667BW Ref - SXS/I&W
Amana ARSE66MBB Ref - SXS/I&W
Amana ARSE66MBC Ref - SXS/I&W
Amana ARSE66MBW Ref - SXS/I&W
Amana ARSE66ZBB  Ref - SXS/I&W
Amana ARSE66ZBC  Ref - SXS/I&W
Amana ARSE66ZBS  Ref - SXS/I&W
Amana ARSE66ZBW  Ref - SXS/I&W
Amana ARSE67RBB  Ref - SXS/I&W
Amana ARSE67RBC  Ref - SXS/I&W
Amana ARSE67RBS  Ref - SXS/I&W
Amana ARSE67RBW  Ref - SXS/I&W
Amana ART1805BC Ref - Top Mount
Amana ART1805BW Ref - Top Mount
Amana ART2105BB Ref - Top Mount
Amana ART2105BC Ref - Top Mount
Amana ART2105BW Ref - Top Mount
Amana ART2107BB Ref - Top Mount
Amana ART2107BC Ref - Top Mount
Amana ART2107BS Ref - Top Mount
Amana ART2107BW Ref - Top Mount
Amana ART2127AB Ref - Top Mount
Amana ART2127AC Ref - Top Mount
Amana ART2127AS Ref - Top Mount
Amana ART2127AW Ref - Top Mount
Amana ART2129ABR Ref - Top Mount
Amana ART2129ACR Ref - Top Mount
Amana ART2129ASR Ref - Top Mount
Amana ART2129AWR Ref - Top Mount
Amana ART2527AB Ref - Top Mount
Amana ART2527AC Ref - Top Mount
Amana ART2527AW Ref - Top Mount
Amana ART5400L Range - Std Mwave Ele
Amana ART5400W Range - Std Mwave Ele
Amana ART6000L Range - S/c S/i Ddraft Gas
Amana ART6000W Range - S/c S/i Ddraft Gas
Amana ART6001L Range - S/c S/i Ddraft Gas
Amana ART6001W Range - S/c S/i Ddraft Gas
Amana ART6002L Range - S/c S/i Ddraft Gas
Amana ART6002W Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 10-16-2009, 04:42 PM
Junior Member
Default
Quote:
looking for some help i replaced timer,
  #3 (permalink)
Old 10-16-2009, 06:07 PM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Replacement parts for AMANA ARS2667BC | AppliancePartsPros.com
Rotate the timer cam till the evaporator and compressor fans shut off.
You are now in a defrost cycle.
Check to see if the defrost heater comes on.
Be careful do not burn your fingers
If yes you probably have a defective timer.
If no it is probably either
A. The defrost heater should be around 20 ohms
B. The defrost thermostat should be 0 ohms when frozen. Note it opens just above freezing.
Here are a couple good sites with basic fridge repair info.
http://www.applianceaid.com/refrigerator.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
bottom drawer freezer leaks pools inside freezer brian c Refrigerator & Freezer Repair 1 03-12-2009 06:49 PM
frost free refrigerator/freezer frosting over on back wall or bottom freezer bwheeler Refrigerator & Freezer Repair 0 01-29-2009 04:57 PM
Frost Build-Up in freezer (refrig & freezer not as Cold as usual) boots1 Oven Repair (including Ranges and Cooktops) 1 01-18-2009 04:08 AM
Freezer cold, evaporator fan not working, frost build up in freezer heretolearn2 Refrigerator & Freezer Repair 3 05-28-2008 03:45 PM
Refrigerator/Freezer has liquid leaking inside freezer and frig terrib Refrigerator & Freezer Repair 0 12-25-2007 11:15 PM
