Hello - I have an Absocold fridge I bought from home depot about 10 years ago. Its in the basement for storing overflow food and mostly beer. I noticed some of the food was freezing recently so I started taking temps. Its way too cold. Even near the bottom I am reading 29 degrees when the temp control is on the lowest setting. This is not a frost free. It has the freezer icebox up top. If I turn the dial down and up I do hear it click around the "1" spot. It is not running all the time, just too cold. Is there anything else I can check? I have attached pics with model sticker , etc. Thank you!!
