I recently replaced the water inlet valve on this model because it was leaking. The water dispenser works fine however it is not making ice any longer. I disconnected the ice maker water line from the back of the fridge and it will pump what looks to be a small amount of water into a cup on the floor. However when connected it does not put any water into the ice maker mold tray. Any suggestions?
