david_tx
#1 Posted : Thursday, December 19, 2013 12:12:23 PM(UTC)
david_tx
While moving the movers removed the doors, and put the door back on with hose jammed between the pin on which the door sits causing the hose to tear. The leak appears to be part of the tube, which is just inside the freezer door, from the bottom so not able to seal it or masking tape it. Is there a way to easily replace that tube without removing the door seal or other simple option to fix the leak.
