Discuss
GE GBS22HCPAWW - Refrigerator not cooling, but freezer is working
 in
Refrigerator & Freezer Repair
Is is possible that a small section (maybe an inch) of the door gasket that isn't sealing properly cause
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE GBS22HCPAWW - Refrigerator not cooling, but freezer is working
  #11 (permalink)
Old 10-23-2009, 05:57 PM
drl213 drl213 is offline
Junior Member
drl213 is on a distinguished road
Default
Is is possible that a small section (maybe an inch) of the door gasket that isn't sealing properly cause the entire freezer wall to freeze over? Even after just a few days?
  #12 (permalink)
Old 11-02-2009, 05:51 PM
Junior Member
Default
Hi, another update.
It seems the wire I was using to trigger the manual defrost was bad, so I tried it again with a new one and got the defrost cycle to activate so it does seem that the motherboard is bad!
Now I have another question/concern. Since this is the 2nd motherboard I'll be replacing in 3 months, what could be causing them to malfunction like this? Seems like a very strange coincidence that I just happen to get 2 bad ones? I definitely don't want to go through all this again in a month or 2, is there something else I should be looking for to prevent it from happening again?
  #13 (permalink)
Old 11-02-2009, 09:38 PM
Qtip Qtip is offline
Member
Qtip is on a distinguished road
Default
Seems to be a defrost problem - let freezer thaw out completely and find the defrost timer - use a flathead screwdriver to manually advance defrost timer until it clicks into defrost mode (if still no heat from def. heater element then most likely replacing def element(s), def. thermostat and def. timer will fix your problem)
  #14 (permalink)
Old 11-03-2009, 02:43 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I would put a 1000 joule surge protector on the fridg. wall outlet, a power surge may be the problem. Make sure you get a surge protector designed for appliances including refrigerators.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator not cooling, but freezer is working cdnhawk02 Refrigerator & Freezer Repair 19 10-16-2009 08:39 AM
Freezer working ok, refrigerator not cooling nabooton Refrigerator & Freezer Repair 1 09-30-2009 07:42 PM
Refrigerator not cooling, but freezer is working geri Refrigerator & Freezer Repair 28 09-14-2009 03:04 PM
refrigerator not cooling, freezer working lvig Refrigerator & Freezer Repair 6 06-29-2009 05:22 PM
Freezer working, Refrigerator not cooling ntlreds Refrigerator & Freezer Repair 0 12-29-2007 11:18 AM
