Hi
I'm having problems with the icemaker on this fridge. it just stopped making ice. the lever is down. sometimes, in the past, it would flip up by itself and quit making ice. the water dispenser works fine. the ice container is pushed up against the back and the end that pushes on the switch is in the "right" place. but is not contacting the switch.
Any ideas on what has happened? or how to fix?
Ron
