Discuss
icemaker leak in cube tray
 in
Refrigerator & Freezer Repair
there is frozen water in the icecube tray. looks like water is leaking out of the icemaker and freezing in
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » icemaker leak in cube tray
  #1 (permalink)
Old 11-21-2013, 11:22 AM
Junior Member
ptora is on a distinguished road
Default icemaker leak in cube tray
Model Number: mfd2560hew   Brand: Maytag   Age: 5 - 10 years
there is frozen water in the icecube tray. looks like water is leaking out of the icemaker and freezing in the tray. is this a water valve problem or icemaker problem?
Related Models
Maytag MFD2560HEW REF - BOTTOM MOUNTS
Maytag MFD2561HEB REF - BOTTOM MOUNTS
Maytag MFD2561HEQ REF - BOTTOM MOUNTS
Maytag MFD2561HEQ14 REFRIGERATOR
Maytag MFD2561HES REF - BOTTOM MOUNTS
Maytag MFD2561HEW REF - BOTTOM MOUNTS
Maytag MFD2561KES REF - BOTTOM MOUNTS
Maytag MFD2562KEB10 REFRIGERATOR
Maytag MFD2562KEB11 REFRIGERATOR
Maytag MFD2562KES10 REFRIGERATOR
Maytag MFD2562KES11 REFRIGERATOR
Maytag MFD2562KEW10 REFRIGERATOR
Maytag MFD2562KEW11 REFRIGERATOR
Maytag MFD2562VEA1 REFRIGERATOR
Maytag MFD2562VEA10 REFRIGERATOR
Maytag MFD2562VEA2 REFRIGERATOR
Maytag MFD2562VEB1 REFRIGERATOR
Maytag MFD2562VEB10 REFRIGERATOR
Maytag MFD2562VEB2 REFRIGERATOR
Maytag MFD2562VEB3 REFRIGERATOR
Maytag MFD2562VEM1 REFRIGERATOR
Maytag MFD2562VEM10 REFRIGERATOR
Maytag MFD2562VEM2 REFRIGERATOR
Maytag MFD2562VEM3 REFRIGERATOR
Maytag MFD2562VEM4 REFRIGERATOR
Maytag MFD2562VEW1 REFRIGERATOR
Maytag MFD2562VEW10 REFRIGERATOR
Maytag MFD2562VEW2 REFRIGERATOR
Roper MFE14XW0 Microwaves*
Roper MFE14XW1 Microwaves*
Maytag MFF2258VEA10 REFRIGERATOR
Maytag MFF2258VEB10 REFRIGERATOR
Maytag MFF2258VEB2 REFRIGERATOR
Maytag MFF2258VEB3 REFRIGERATOR
Maytag MFF2258VEM2 REFRIGERATOR
Maytag MFF2258VEM3 REFRIGERATOR
Maytag MFF2258VEM4 REFRIGERATOR
Maytag MFF2258VEW10 REFRIGERATOR
Maytag MFF2258VEW2 REFRIGERATOR
Maytag MFF2557HEB REF - BOTTOM MOUNTS
Maytag MFF2557HEB14 REFRIGERATOR
Maytag MFF2557HEQ REF - BOTTOM MOUNTS
Maytag MFF2557HES REF - BOTTOM MOUNTS
Maytag MFF2557HEW REF - BOTTOM MOUNTS
Maytag MFF2557KES REF - BOTTOM MOUNTS
Maytag MFF2558KEB REF - BOTTOM MOUNTS
Maytag MFF2558KEB11 REFRIGERATOR
Maytag MFF2558KES REF - BOTTOM MOUNTS
Maytag MFF2558KES12 REFRIGERATOR
Maytag MFF2558KEW REF - BOTTOM MOUNTS
Maytag MFF2558KEW11 REFRIGERATOR
Maytag MFF2558VEA1 REFRIGERATOR
Maytag MFF2558VEA10 REFRIGERATOR
Maytag MFF2558VEA2 REFRIGERATOR
Maytag MFF2558VEB1 REFRIGERATOR
Maytag MFF2558VEB10 REFRIGERATOR
Maytag MFF2558VEB2 REFRIGERATOR
Maytag MFF2558VEB3 REFRIGERATOR
Maytag MFF2558VEM1 REFRIGERATOR
Maytag MFF2558VEM10 REFRIGERATOR
Maytag MFF2558VEM2 REFRIGERATOR
Maytag MFF2558VEM3 REFRIGERATOR
Maytag MFF2558VEM4 REFRIGERATOR
Maytag MFF2558VEQ1 REFRIGERATOR
Maytag MFF2558VEQ10 REFRIGERATOR
Maytag MFF2558VEQ2 REFRIGERATOR
Maytag MFF2558VEW1 REFRIGERATOR
Maytag MFF2558VEW10 REFRIGERATOR
Maytag MFF2558VEW2 REFRIGERATOR
Frigidaire MFF312BFWB Frg(v1) / Electric Range
Frigidaire MFF312BFWC Frg(v2) / Electric Range
Frigidaire MFF312BFWE Frg(v3) / Electric Range
Frigidaire MFF312BSF ELECTRIC RANGE
Frigidaire MFF312HSC ELECTRIC RANGE
Frigidaire MFF318BGDA Wwh(v1) / Electric Range
Frigidaire MFF318BGWA Wwh(v2) / Electric Range
Frigidaire MFF351BCWC Frg(v1) / Electric Range
Frigidaire MFF351BCWD Frg(v2) / Electric Range
Frigidaire MFF351BCWE Frg(v3) / Electric Range
Maytag MFI2067AEB REF - BOTTOM MOUNTS
Maytag MFI2067AEB12 REFRIGERATOR
Maytag MFI2067AEB13 REFRIGERATOR
Maytag MFI2067AEB4 REFRIGERATOR
Maytag MFI2067AEB5 REFRIGERATOR
Maytag MFI2067AEQ REF - BOTTOM MOUNTS
Maytag MFI2067AEQ12 REFRIGERATOR
Maytag MFI2067AEQ13 REFRIGERATOR
Maytag MFI2067AEQ4 REFRIGERATOR
Maytag MFI2067AES REF - BOTTOM MOUNTS
Maytag MFI2067AES12 REFRIGERATOR
Maytag MFI2067AES13 REFRIGERATOR
Maytag MFI2067AES4 REFRIGERATOR
Maytag MFI2067AES5 REFRIGERATOR
Maytag MFI2067AES6 REFRIGERATOR
Maytag MFI2067AEW REF - BOTTOM MOUNTS
Maytag MFI2067AEW12 REFRIGERATOR
Maytag MFI2067AEW13 REFRIGERATOR
Maytag MFI2067AEW4 REFRIGERATOR
Maytag MFI2266AEB10 REFRIGERATOR
Maytag MFI2266AEB11 REFRIGERATOR
Maytag MFI2266AEQ10 REFRIGERATOR
Maytag MFI2266AEQ11 REFRIGERATOR
Maytag MFI2266AES10 REFRIGERATOR
Maytag MFI2266AES11 REFRIGERATOR
Maytag MFI2266AEU10 REFRIGERATOR
Maytag MFI2266AEU11 REFRIGERATOR
Maytag MFI2266AEW10 REFRIGERATOR
Maytag MFI2266AEW11 REFRIGERATOR
Maytag MFI2269VEA1 REFRIGERATOR
Maytag MFI2269VEA10 REFRIGERATOR
Maytag MFI2269VEB1 REFRIGERATOR
Maytag MFI2269VEB10 REFRIGERATOR
Maytag MFI2269VEB2 REFRIGERATOR
Maytag MFI2269VEM1 REFRIGERATOR
Maytag MFI2269VEM10 REFRIGERATOR
Maytag MFI2269VEM2 REFRIGERATOR
Maytag MFI2269VEM3 REFRIGERATOR
Maytag MFI2269VEQ1 REFRIGERATOR
Maytag MFI2269VEQ10 REFRIGERATOR
Maytag MFI2269VEW1 REFRIGERATOR
  #2 (permalink)
Old 11-21-2013, 01:16 PM
Senior Member
Appliance Ninja is on a distinguished road
Default
The most likely to be at fault is the water inlet valve. Are the ice cubes of normal size or do you find they are all too large and stuck together?
  #3 (permalink)
Old 11-21-2013, 03:16 PM
Junior Member
Default
hi thanks for the info. ice cubes are regular size but there is one spot under the icemaker that has the frozen water leak under it and a clump of frozen water and ice cubes stuck to it. i will open the back panel and remove the valve for replacing. thanks again!
  #4 (permalink)
Old 11-21-2013, 04:02 PM
Junior Member
Default
i dont know how to remove the valve! would you be able to give me some guidance?
  #5 (permalink)
Old 11-21-2013, 04:47 PM
Senior Member
Default
The mounting plate (number 2) will come free after a few screws have been removed, allowing access to remove the valve (number 10). If your hoses do not unscrew from your existing valve, they have what are called Guest fittings. To release them, you have to hold the little plastic washer in that is near the the valve at each hose and pull the hose out. That washer is what releases the hoses, so be sure you press them in. Take note (and maybe even a picture) of where the hoses are on the valve to avoid confusion when replacing the valve. The correct part for your model is available at the link below.
Whirlpool 67005154 Water Inlet Valve - AppliancePartsPros.com
  #6 (permalink)
Old 11-21-2013, 06:36 PM
Junior Member
Default
ok i got the part out and went and got a new one. i wasn't thinking and didn't take a picture before i took all the hoses out so now im not sure which hose goes where. there are two connections on the back and one on the front of the part. does the line coming out of the filter go into the one connection on the back? this is where i am stuck now!!!! oh boy. thanks again for your help!!!
  #7 (permalink)
Old 11-21-2013, 06:49 PM
Senior Member
Default
Yes, the single connector is where the inlet line from the filter goes. The other tow fittings are sized differently so they will only go one way. Just push the tubes in very firmly until they lock into place.
  #8 (permalink)
Old 11-21-2013, 09:49 PM
Junior Member
Default
thats what i thought. it was all good but now there is water all over the floor! i turned the water off so now i just have to figure out what i did wrong. i checked to make sure the hoses were on tight before i closed everything up so i don't know why its leaking. is it possible they weren't on tight enough? i will recheck tomorrow unless there is another reason. hope you have a good night and thank you!
  #9 (permalink)
Old 11-22-2013, 07:48 AM
Senior Member
Default
Make sure the tubing is pushed in very tight. If you removed plastic compression nuts to accommodate the new valve fittings, you may need to cut that tubing back just a bit so you have a smooth surface for the rubber O ring in each of the fittings to seal around. If you need to remove those lines, be sure to hold in that plastic washer then pull them out. Do not forcefully pull them out or the valve will be damaged.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing Ice Cube Tray mcmom Refrigerator & Freezer Repair 1 10-01-2013 08:44 AM
Ice Cube Tray stuck in flipped position lkhodges8 Refrigerator & Freezer Repair 0 03-17-2012 10:58 AM
water drip in icemaker, freezes ice cube hank b Refrigerator & Freezer Repair 1 03-25-2011 08:46 AM
Icemaker leaking into cube pan jwes Refrigerator & Freezer Repair 1 06-26-2010 06:34 AM
leak in ice maker freezea inside cube holder MORRISRO10 Refrigerator & Freezer Repair 0 02-03-2010 05:07 AM
