Discuss
whirlpool side by side not cooling
 in
Refrigerator & Freezer Repair
ok, I ordered thepart. In the meantime I checked the resistance between those two small square holes on the side
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » whirlpool side by side not cooling
  #11 (permalink)
Old 11-21-2013, 08:56 AM
Junior Member
fordtech48 is on a distinguished road
Default
ok, I ordered thepart. In the meantime I checked the resistance between those two small square holes on the side of the device below where the capacitor plugs in. They are the 2 holes I thought you might be referring to last night but didn't have anything small enough to go in there. I have some very small pin type connectors for my fluke meter here at work and they go in those 2 holes and read .7 ohms.
I also plugged the capacitor back into the start device and checked the resistance between the 2 side by side compressor terminals and it was very high in the megaohms indicating an open. The weird thing was the meter might have charged the capacitor because when I checked it for dc voltage it had around 1.1 volt and slowly bled off with my meter leads attached.
Edit: I don't think the meter charged the capacitor through the relay- I believe the capacitor had some residual voltage on it from when the frig was running 2 days ago- I shorted the terminals together and checked it-the capacitor was dead on the money 12 micro farads. After doing the capacitance test the capacitor had charged up a very minute amount of voltage- like .1 volt.
I will update when I get the new start relay and verify the repair.
  #12 (permalink)
Old 11-21-2013, 10:20 AM
Senior Member
Appliance Ninja is on a distinguished road
Default
I believe that start device is indeed faulty. You should be good to go once you replace it.
  #13 (permalink)
Old 11-22-2013, 04:30 PM
Junior Member
Default Now I'm pissed
Well, so much for that. The start device did NOT fix anything and is doing the same thing as before. I also ohm tested the new part and there is no continuity between the terminals on the new one either. I said there was no heavy rattling when shaken, the new one has the same light tick as I said the old one did. I was told there should be continuity between two of the terminals that plug into the compressor and that was obviously not the case for this part. Thanks for making sure I blew 50.00 of my hard earned money though. I really appreciate being pushed over and over to buy a part from you guys that was not needed!!!!
Frig still broken.
  #14 (permalink)
Old 11-22-2013, 04:45 PM
Senior Member
Default
First of all, I am not part of "you guys." I am a volunteer tech that enjoys helping and I make not one cent on any part of that help or any parts sale. Second, you can send that part back for a full refund. I only have what information you provide to go by, so that is what I based my diagnosis on. The information you provided suggests that the relay was bad. It is indeed hard to find good FREE help these days, isn't it?!
  #15 (permalink)
Old 11-22-2013, 06:44 PM
Junior Member
Default
Quote:
Yeah, it's hard to find knowledgeable help these days. If I had access to the wiring diagram I could have diagnosed it and saved time and money. I assumed you knew how to diagnose this start relay and were aware of what terminals go where on the inside of the device. Obviously that is not the case. The terminals you said should have 4-5 ohms would only have that reading if the device was powered and the relay contacts were closed. I have been working on electrical circuits since being trained in the military in 1985.
How does the information I suggested indicate the relay is bad? I stated there was no loud rattling- the new device has the same tiny tick when shaken- and I gave my resistance testing results- which don't indicate a faulty device as the new device has the same readings.
Since when are opened electrical parts returnable?
  #16 (permalink)
Old 11-22-2013, 06:56 PM
Senior Member
Default
I don't intend to argue with you, it was only my intent to help. I appreciate and thank you for your service to our country and appreciate your frustration from that your refrigerator is broken. This site does indeed take back installed electrical parts, so you can send it back. Have a good evening in spite of your broken refrigerator.
  #17 (permalink)
Old 11-22-2013, 07:06 PM
Senior Member
Default
The information below is directly from the service manual published by the manufacturer. That is what I based my diagnosis on.
  #18 (permalink)
Old 11-22-2013, 07:22 PM
Junior Member
Default
Then I got a bad new part? I doubt it. Don't know what service manual that came out of but it's wrong.
Thinking about it I think the compressor is bad. It's getting the command to turn on and after a few seconds it's overloading and shutting off. That's why it's getting so hot even though it's not actually running. High Mechanical resistance causes excessive current draw and would cause the overload circuit to shut off the relay- hence the clicking on and off. Funny, in 8 years I never heard that relay click one time.
The only problem I ever had was the ice maker motor going bad which I diagnosed and repaired with no wiring diagram.
  #19 (permalink)
Old 11-22-2013, 07:28 PM
Senior Member
Default
Okay, well anyway, I just wanted to let you know you can return that part and show you how the manufacturers (all of them) recommend testing the PTC relays. I hope you have a great evening.
  #20 (permalink)
Old 11-22-2013, 07:33 PM
Senior Member
Default
As a parting thought, that relay is not a wire wound one that will click, as you say you have not heard. The link below explains how the PTC relay works....
PTC Relays | Learn refrigeration
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Side by side whirlpool refrigerator not cooling! J1love Refrigerator & Freezer Repair 1 07-11-2013 03:54 AM
WHirlpool Side by Side suddenly not cooling tex6688 Refrigerator & Freezer Repair 1 05-26-2012 11:39 PM
Whirlpool Side-by-Side Not Cooling All The Time rolltideandy Refrigerator & Freezer Repair 2 04-11-2012 08:24 AM
Whirlpool Side by side stopped cooling kkamdertz Refrigerator & Freezer Repair 0 04-16-2011 07:21 AM
Whirlpool Side by Side not cooling/freeezing! Help! relaxednoma Refrigerator & Freezer Repair 11 11-04-2010 05:49 AM
