Discuss
As Easy as a Fan Replacement?
 in
Refrigerator & Freezer Repair
Greetings all, I have a Sub Zero 642 side-by-side, circa 2000. I noticed recently that a portion of the interior
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » As Easy as a Fan Replacement?
  #1 (permalink)
Old 11-19-2013, 01:11 PM
Junior Member
Captain Spalding is on a distinguished road
Default As Easy as a Fan Replacement?
Model Number: 642   Brand: Sub Zero   Age: More than 10 years
Greetings all,
I have a Sub Zero 642 side-by-side, circa 2000. I noticed recently that a portion of the interior wall between compartments was uncomfortably warm to the touch. Investigation revealed that the condenser fan wasn't running. What's interesting is that when the compressor is running, if I give the fan blade a spin, the fan will run. I've been running the unit with the panel off and the works exposed. Sometimes the fan comes on with the compressor and sometimes it doesn't. If I give it a spin, it runs. When the fan runs, the interior wall of the compartment is no longer warm.
It seems obvious to me that it's time for a new fan. While I consider myself "handy", I also know that I'm no expert on appliance repair, so I thought I'd better consult with wiser minds before making any assumptions. Could there be anything else going on besides a bad fan?
Related Models
Magic Chef 6458XRA RANGE- S/C S/I GAS
Magic Chef 6458XRS RANGE- S/C S/I GAS
Magic Chef 6458XRW RANGE- S/C S/I GAS
Magic Chef 6458XTA RANGE- S/C S/I GAS
Magic Chef 6458XTS RANGE- S/C S/I GAS
Magic Chef 6458XTW RANGE- S/C S/I GAS
Kenmore 6476037210 KENMORE 30 IN GAS RANGE
Kenmore 6476037220 KENMORE 30 IN GAS RANGE
Kenmore 6476037240 KENMORE 30 IN GAS RANGE
Kenmore 6476037260 KENMORE 30 IN GAS RANGE
Kenmore 6476037310 KENMORE 30 IN GAS RANGE
Kenmore 6476037311 KENMORE 30 INCH GAS RANGE
Kenmore 6476037312 KENMORE 30 IN GAS RANGE
Kenmore 6476037313 KENMORE 30 INCH GAS RANGE
Kenmore 6476037320 KENMORE 30 IN GAS RANGE
Kenmore 6476037321 KENMORE 30 INCH GAS RANGE
Kenmore 6476037322 KENMORE 30 IN GAS RANGE
Kenmore 6476037323 KENMORE 30 INCH GAS RANGE
Kenmore 6476037340 KENMORE 30 IN GAS RANGE
Kenmore 6476037341 KENMORE 30 INCH GAS RANGE
Kenmore 6476037342 KENMORE 30 IN GAS RANGE
Kenmore 6476037343 KENMORE 30 INCH GAS RANGE
Kenmore 6476037360 KENMORE 30 IN GAS RANGE
Kenmore 6476037361 KENMORE 30 INCH GAS RANGE
Kenmore 6476037362 KENMORE 30 IN GAS RANGE
Kenmore 6476037363 KENMORE 30 INCH GAS RANGE
Kenmore 6476037510 KENMORE 30 INCH GAS RANGE
Kenmore 6476037520 KENMORE 30 INCH GAS RANGE
Kenmore 6476037540 KENMORE 30 INCH GAS RANGE
Kenmore 6476037560 KENMORE 30 INCH GAS RANGE
Kenmore 6476047510 KENMORE 30 INCH GAS RANGE
Kenmore 6476047520 KENMORE 30 INCH GAS RANGE
Kenmore 6476047540 KENMORE 30 INCH GAS RANGE
Kenmore 6476047560 KENMORE 30 INCH GAS RANGE
Kenmore 6476057210 KENMORE 30 IN GAS RANGE
Kenmore 6476057220 KENMORE 30 IN GAS RANGE
Kenmore 6476057240 KENMORE 30 IN GAS RANGE
Kenmore 6476057260 KENMORE 30 IN GAS RANGE
Kenmore 6476057310 KENMORE GAS RANGE
Kenmore 6476057311 KENMORE 30 IN GAS RANGE
Kenmore 6476057312 KENMORE 30 INCH GAS RANGE
Kenmore 6476057313 KENMORE 30 INCH GAS RANGE
Kenmore 6476057320 KENMORE GAS RANGE
Kenmore 6476057321 KENMORE 30 IN GAS RANGE
Kenmore 6476057322 KENMORE 30 INCH GAS RANGE
Kenmore 6476057323 KENMORE 30 INCH GAS RANGE
Kenmore 6476057340 KENMORE GAS RANGE
Kenmore 6476057341 KENMORE 30 IN GAS RANGE
Kenmore 6476057342 KENMORE 30 INCH GAS RANGE
Kenmore 6476057343 KENMORE 30 INCH GAS RANGE
Kenmore 6476057360 KENMORE GAS RANGE
Kenmore 6476057361 KENMORE 30 IN GAS RANGE
Kenmore 6476057362 KENMORE 30 INCH GAS RANGE
Kenmore 6476057363 KENMORE 30 INCH GAS RANGE
Kenmore 6476057510 KENMORE 30 INCH GAS RANGE
Kenmore 6476057520 KENMORE 30 INCH GAS RANGE
Kenmore 6476057540 KENMORE 30 INCH GAS RANGE
Kenmore 6476057560 KENMORE 30 INCH GAS RANGE
Kenmore 6476137210 KENMORE 30 IN GAS RANGE
Kenmore 6476137220 KENMORE 30 IN GAS RANGE
Kenmore 6476137240 KENMORE 30 IN GAS RANGE
Kenmore 6476137260 KENMORE 30 IN GAS RANGE
Kenmore 6476137310 KENMORE 30 IN GAS RANGE
Kenmore 6476137311 KENMORE 30 INCH GAS RANGE
Kenmore 6476137312 KENMORE 30 IN GAS RANGE
Kenmore 6476137313 KENMORE 30 INCH GAS RANGE
Kenmore 6476137320 KENMORE 30 IN GAS RANGE
Kenmore 6476137321 KENMORE 30 INCH GAS RANGE
Kenmore 6476137322 KENMORE 30 IN GAS RANGE
Kenmore 6476137323 KENMORE 30 INCH GAS RANGE
Kenmore 6476137340 KENMORE 30 IN GAS RANGE
Kenmore 6476137341 KENMORE 30 INCH GAS RANGE
Kenmore 6476137342 KENMORE 30 IN GAS RANGE
Kenmore 6476137343 KENMORE 30 INCH GAS RANGE
Kenmore 6476137360 KENMORE 30 IN GAS RANGE
Kenmore 6476137361 KENMORE 30 INCH GAS RANGE
Kenmore 6476137362 KENMORE 30 IN GAS RANGE
Kenmore 6476137363 KENMORE 30 INCH GAS RANGE
Kenmore 6476157210 KENMORE 30 IN GAS RANGE
Kenmore 6476157220 KENMORE 30 IN GAS RANGE
Kenmore 6476157240 KENMORE 30 IN GAS RANGE
Kenmore 6476157260 KENMORE 30 IN GAS RANGE
Kenmore 6476157310 KENMORE GAS RANGE
Kenmore 6476157311 KENMORE 30 IN GAS RANGE
Kenmore 6476157312 KENMORE 30 INCH GAS RANGE
Kenmore 6476157313 KENMORE 30 INCH GAS RANGE
Kenmore 6476157320 KENMORE GAS RANGE
Kenmore 6476157321 KENMORE 30 IN GAS RANGE
Kenmore 6476157322 KENMORE 30 INCH GAS RANGE
Kenmore 6476157323 KENMORE 30 INCH GAS RANGE
Kenmore 6476157340 KENMORE GAS RANGE
Kenmore 6476157341 KENMORE 30 IN GAS RANGE
Kenmore 6476157342 KENMORE 30 INCH GAS RANGE
Kenmore 6476157343 KENMORE 30 INCH GAS RANGE
Kenmore 6476157360 KENMORE GAS RANGE
Kenmore 6476157361 KENMORE 30 IN GAS RANGE
Kenmore 6476157362 KENMORE 30 INCH GAS RANGE
Kenmore 6476157363 KENMORE 30 INCH GAS RANGE
Kenmore 6476157510 KENMORE 30 INCH GAS RANGE
Kenmore 6476157520 KENMORE 30 INCH GAS RANGE
Kenmore 6476157540 KENMORE 30 INCH GAS RANGE
Kenmore 6476157560 KENMORE 30 INCH GAS RANGE
Kenmore 6476217410 KENMORE 30 INCH ELECTRIC RANGE
Kenmore 6476217411 KENMORE 30 IN ELECTRIC RANGE
Kenmore 6476217412 KENMORE 30 IN ELECTRIC RANGE
Kenmore 6476217416 KENMORE 30 INCH ELECTRIC RANGE
Kenmore 6476217417 KENMORE 30 IN ELECTRIC RANGE
Kenmore 6476217420 KENMORE 30 INCH ELECTRIC RANGE
Kenmore 6476217421 KENMORE 30 IN ELECTRIC RANGE
Kenmore 6476217422 KENMORE 30 IN ELECTRIC RANGE
Kenmore 6476217426 KENMORE 30 INCH ELECTRIC RANGE
Kenmore 6476217427 KENMORE 30 IN ELECTRIC RANGE
Kenmore 6476217440 KENMORE 30 INCH ELECTRIC RANGE
Kenmore 6476217441 KENMORE 30 IN ELECTRIC RANGE
Kenmore 6476217442 KENMORE 30 IN ELECTRIC RANGE
Kenmore 6476217446 KENMORE 30 INCH ELECTRIC RANGE
Kenmore 6476217447 KENMORE 30 IN ELECTRIC RANGE
Kenmore 6476217460 KENMORE 30 INCH ELECTRIC RANGE
Kenmore 6476217461 KENMORE 30 IN ELECTRIC RANGE
Kenmore 6476217462 KENMORE 30 IN ELECTRIC RANGE
  #2 (permalink)
Old 11-19-2013, 01:35 PM
Senior Member
Appliance Ninja is on a distinguished road
Default
That is actually a pretty common failure and will likely only require replacing that condenser fan motor. That fan is available below!
Pro TJSM0740 Fan Motor - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Easy question... zeus1gdsm Dryer Repair 3 02-11-2012 05:14 AM
Replacement was easy Weekender2012 Oven Repair (including Ranges and Cooktops) 1 01-21-2012 06:30 PM
Washer, rear outer tub replacement.How easy? nomadad Washer Repair 0 01-25-2009 03:07 PM
looks easy enough hi-topp Washer Repair 1 12-04-2007 03:07 PM
