Discuss
Freezer not cold enough
 in
Refrigerator & Freezer Repair
I have an Amana ARS9169AS. The freezer has suddenly stopped keeping things frozen. It does keep things about fridge temp
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer not cold enough
  #1 (permalink)
Old 11-08-2013, 02:28 PM
Junior Member
mjcompanies is on a distinguished road
Default Freezer not cold enough
Model Number: ARS9169AS   Brand: Amana   Age: 5 - 10 years
I have an Amana ARS9169AS. The freezer has suddenly stopped keeping things frozen. It does keep things about fridge temp (just won't freeze), and the fridge side seems to be about right but barely cold enough.
First I cleaned all the coils. They were SO dirty that I thought it was not getting any air and could have been the culprit. Waited a day and no change. The compressor runs as it should, the compressor fan runs, and the evaporator fan runs. The defrost thermostat tested good, but only the top evaporator coil had any frost on it.
With this info I am assuming I have a refrigeration issue? I don't know much about appliances (but I am learning), and I don't want to replace the fridge if I have missed something. Any ideas???
Related Models
Amana ARS9169AS REF - SXS/I&W
Amana ARS9265BB REF - SXS/I&W
Amana ARS9265BC REF - SXS/I&W
Amana ARS9265BW REF - SXS/I&W
Amana ARS9266BS REF - SXS/I&W
Amana ARS9268BB REF - SXS/I&W
Amana ARS9268BC REF - SXS/I&W
Amana ARS9268BW REF - SXS/I&W
Amana ARS9269BS REF - SXS/I&W
Amana ARSE664BB REF - SXS/I&W
Amana ARSE664BC REF - SXS/I&W
Amana ARSE664BS REF - SXS/I&W
Amana ARSE664BW REF - SXS/I&W
Amana ARSE665BB REF - SXS/I&W
Amana ARSE665BC REF - SXS/I&W
Amana ARSE665BS REF - SXS/I&W
Amana ARSE665BW REF - SXS/I&W
Amana ARSE667BB REF - SXS/I&W
Amana ARSE667BC REF - SXS/I&W
Amana ARSE667BS REF - SXS/I&W
Amana ARSE667BW REF - SXS/I&W
Amana ARSE66MBB REF - SXS/I&W
Amana ARSE66MBC REF - SXS/I&W
Amana ARSE66MBW REF - SXS/I&W
Amana ARSE66ZBB REF - SXS/I&W
Amana ARSE66ZBC REF - SXS/I&W
Amana ARSE66ZBS REF - SXS/I&W
Amana ARSE66ZBW REF - SXS/I&W
Amana ARSE67RBB REF - SXS/I&W
Amana ARSE67RBC REF - SXS/I&W
Amana ARSE67RBS REF - SXS/I&W
Amana ARSE67RBW REF - SXS/I&W
Amana ART1805BC REF - TOP MOUNT
Amana ART1805BW REF - TOP MOUNT
Amana ART2105BB REF - TOP MOUNT
Amana ART2105BC REF - TOP MOUNT
Amana ART2105BW REF - TOP MOUNT
Amana ART2107BB REF - TOP MOUNT
Amana ART2107BC REF - TOP MOUNT
Amana ART2107BS REF - TOP MOUNT
Amana ART2107BW REF - TOP MOUNT
Amana ART2127AB REF - TOP MOUNT
Amana ART2127AC REF - TOP MOUNT
Amana ART2127AS REF - TOP MOUNT
Amana ART2127AW REF - TOP MOUNT
Amana ART2129ABR REF - TOP MOUNT
Amana ART2129ACR REF - TOP MOUNT
Amana ART2129ASR REF - TOP MOUNT
Amana ART2129AWR REF - TOP MOUNT
Amana ART2527AB REF - TOP MOUNT
Amana ART2527AC REF - TOP MOUNT
Amana ART2527AW REF - TOP MOUNT
Amana ART5400L RANGE- STD MWAVE ELE
Amana ART5400W RANGE- STD MWAVE ELE
Amana ART6000L RANGE- S/C S/I DDRAFT GAS
Amana ART6000W RANGE- S/C S/I DDRAFT GAS
Amana ART6001L RANGE- S/C S/I DDRAFT GAS
Amana ART6001W RANGE- S/C S/I DDRAFT GAS
Amana ART6002L RANGE- S/C S/I DDRAFT GAS
Amana ART6002L Range - S/c S/i Ddraft Gas
Amana ART6002W RANGE- S/C S/I DDRAFT GAS
Amana ART6002W Range - S/c S/i Ddraft Gas
Amana ART6021C RANGE- S/C S/I DDRAFT GAS
Amana ART6021L RANGE- S/C S/I DDRAFT GAS
Amana ART6021W RANGE- S/C S/I DDRAFT GAS
Amana ART6100E RANGE- S/C S/I DDRAFT GAS
Amana ART6100LL RANGE- S/C S/I DDRAFT GAS
Amana ART6100WW RANGE- S/C S/I DDRAFT GAS
Amana ART6110E RANGE- S/C S/I DDRAFT ELE
Amana ART6110LL RANGE- S/C S/I DDRAFT ELE
  #2 (permalink)
Old 11-09-2013, 12:45 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Yes, unfortunately it does sound like a sealed system problem.
As a double check, you could manually defrost the evaporator/freezer coils.
Then put the evaporator cove back on anfd let it run for a while.
If you still only see frost on the top of the evaporator coils then it is a sealed system problem.
Note be sure that the compressor runs when checking this. if you check it during or shortly after a defrost cycle then you may come to the wrong conclusion.
I am assuming that the compressor runs all the time except whrn the unit goes into defrost.
Below is a link to more info on this type of problem. take a look at the example pictures about half way down the page.
http://www.applianceaid.com/refriger...old-enough.php
__________________
  #3 (permalink)
Old 11-09-2013, 06:44 AM
Junior Member
Default
Mine looks just like example picture one with frost going part way down the top coil and nothing else.
Could it be stuck in defrost mode? I am not sure how to check this, but I thought if that was the case it would feel more like an oven in there. It is about refrigerator warm in the freezer, but not 'hot' to the touch.
Assuming a sealed system problem, I assume I cannot check and/or charge this on my own. I had one place tell me they could come out and check and recharge it and have me going again for about $100. However, I wonder if the problem would just surface again a few months later after things leaked out again (assuming a leak since the compressor runs and sounds normal). They also charge like $40 or $50 to come out for a diagnostic, whether or not they can fix it. Is this something I should take the chance on, or should I just put that money toward a replacement?
  #4 (permalink)
Old 11-09-2013, 07:03 AM
Senior Expert
APP Volunteer
Default
The compressor and fans do not run during defrost.
Also if you touch the defrost heater it would be hot.
There is no use just adding freon as it will just leak out again.
They have to find and repair the leak. If they can find it sometimes it cannot be found. The symptoms can also be caused by other sealed system problems.
In most cases it makes more sense to bite the bullet and buy a new fridge.
__________________
  #5 (permalink)
Old 11-13-2013, 12:47 PM
Junior Member
Default
I did some more checking and I noticed a dent in one of the lines off the compressor. The line is only about 6 inches long and dead-ends, so I am not sure this would matter, but could a dent in the line cause this issue?
Here is a picture of the line and the dent/impression http://i1363.photobucket.com/albums/...ps83a55175.jpg
  #6 (permalink)
Old 11-13-2013, 01:10 PM
Junior Member
barryware is on a distinguished road
Default
The "dent" is how the tube is sealed after charging with refrigerant. The tube is crimped as your picture shows to seal it (temporarily), the refrigerant charging equipment is removed, then the end of the tube is soldered shut for a permanent seal.
It looks normal.
  #7 (permalink)
Old 11-20-2013, 09:45 AM
Junior Member
Default
Whether fixable or not this type of repair is over my head. I replaced it with a new (to me) used fridge. I am now finding out that the unit I put in has VERY slow ice production (like 10-20 cubes/day), but I guess that is a question for a different post.
Thanks for the answers, help, and insight.
  #8 (permalink)
Old 11-20-2013, 11:26 AM
Senior Expert
APP Volunteer
Default
Check your freezer temperature.
It should be 0 to 5 degrees F.
Ice production is dependent on the freezer temperature.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer Cold But Not Freezing; Fridge Compartment Cold & Seems Fine ChuckM12 Refrigerator & Freezer Repair 1 08-29-2012 07:51 AM
Kenmore- freezer is cold but not freezeing- Fefrig is cold dan11 Refrigerator & Freezer Repair 1 02-07-2012 06:22 AM
Outside Refrig/Freezer in Garage does not stay cold in cold weather verno1 Refrigerator & Freezer Repair 2 12-14-2010 12:07 PM
Kenmore w/ Freezer bottom drawer - Blowing Cold Air but not cold enough tvGhouse Refrigerator & Freezer Repair 0 02-25-2009 02:50 PM
Fridge & Freezer Cycle Cold To Warm Back To Cold terkel Refrigerator & Freezer Repair 1 09-25-2007 02:58 AM
