I have discovered a leak in the water line from the bottom of this frig to the ice/water dispenser.
How do you remove the ice/water (inset) from the freezer door. I have removed all the screws and it will not come out, its loose but will not come out.
I need to replace the (water) line that connects to the (water) dispenser and goes down to just behind the (kick plate). I am hoping I can re-route a new section of line, I just can't see without getting that ice/water inset out of the door.
I'm getting a big drip of water coming down that line to the floor.
Thanks for listening,
Brad
