I have a Whirlpool refrig that I have replaced the control board for the water and ice dispenser. It worked ok for awhile, but I think the soft touch key pad was sticking so, it damaged the board again. I don't feel like shelling out another 200 dollars for something that is 8 yrs old. Refrig works fine. I did a jumper for the water dispenser to make the water work since it was locked out, but was wondering if someone know of a jumper I can use for the ice dispenser work. Being an electrician, I know how to get the motor to work, but its a sealed unit and can't find out what operates the ice dispenser motor. Thanks in advance for your help.
John
