The freezer wasn't cooling although the compressor was running. I had no continuity on the defrost control timer nor the defrost timer so I changed both. The freezer side by side does not want to cool even tho I advance the control timer nor does the fan in the freezer come on. What else could I look for in order to get this to work? I would appreciate any recommendations.
Originally Posted by: co199 The freezer wasn't cooling although the compressor was running. I had no continuity on the defrost control timer nor the defrost timer so I changed both. The freezer side by side does not want to cool even tho I advance the control timer nor does the fan in the freezer come on. What else could I look for in order to get this to work? I would appreciate any recommendations. Send info to geraldc92@gmail.com
