This model Samsung uses an icemaker water delivery tube that has a heater. The heater plugs into a fixed socket in the roof of the freezer compartment.
My question is: When is this circuit for the heater energized. When I check with a voltmeter it shows 0 volts. Does this circuit turn on and off with the cycle of the ice maker?
Is there a way to test this circuit?
Serial # for this unit is 954243cx700747 b
Thanks! Gordon French
