Shortly after cleaning the shelves and drawers of my Frigidaire refrigerator (in use a little under 16 months), I noticed the refrigeration compartment wasn't cooling properly. I've always kept the temp control set very slightly warmer than the "normal" hash mark (at the 10 o'clock position) to maintain @ about 38 degrees. Since, I've had to position the control at 12 o'clock to maintain @ 39-41 (a bit high for my comfort level)..
I haven't noticed the unit running excessively. Not surprisingly, the freezer section is holding a bit cooler @ -5 to zero instead of the usual 0 to 5.
All comments & suggestions welcome.
Thanks as always,
jimII
