Discuss
Leak at Water Filter Interface
 in
Refrigerator & Freezer Repair
Hi Guys, This fridge is the french door type with the bottom freezer. The water filter installs between the two
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Leak at Water Filter Interface
  #1 (permalink)
Old 09-28-2013, 02:40 PM
Junior Member
danplaysbass is on a distinguished road
Default Leak at Water Filter Interface
Model Number: RFG298HDRS   Brand: Samsung   Age: 1 - 5 years
Hi Guys,
The water filter installs between the two drawers and above the long deli drawer. Its a long cylindrical filter with two rings where you push it in and rotate clockwise to lock it in place.
I noticed water pooling in the deli drawer and was able to see that it was leaking where the filter interface is. I removed the filter as this unit has the auto bypass option where it can bypass the filter interface and still work. I believe this works so that when the filter is locked in it pushes two spring loaded pins that allows the water to flow into and out of the filter. When no filter is there the springs push it closed so water bypasses it.
Now with the filter removed I am seeing leakage from the bottom pin. Thoughts?
Related Models
Amana RFS10 COMMERCIAL MICROWAVES
Amana RFS10B COMMERCIAL MICROWAVES
Amana RFS10MP COMMERCIAL MICROWAVES
Amana RFS10MP2 COMMERCIAL MICROWAVES
Amana RFS10S COMMERCIAL MICROWAVES
Amana RFS10SE COMMERCIAL MICROWAVES
Amana RFS10SW2 COMMERCIAL MICROWAVES
Amana RFS10SW2A COMMERCIAL MICROWAVES
Amana RFS11B COMMERCIAL MICROWAVES
Amana RFS11BT COMMERCIAL MICROWAVES
Amana RFS11LW COMMERCIAL MICROWAVES
Amana RFS11LWT COMMERCIAL MICROWAVES
Amana RFS11MP2 COMMERCIAL MICROWAVES
Amana RFS11MP2T COMMERCIAL MICROWAVES
Amana RFS11MPLW COMMERCIAL MICROWAVES
Amana RFS11MPLWT COMMERCIAL MICROWAVES
Amana RFS11SW2 COMMERCIAL MICROWAVES
Amana RFS11SW2T COMMERCIAL MICROWAVES
Amana RFS12MPS COMMERCIAL MICROWAVES
Amana RFS12MPSA COMMERCIAL MICROWAVES
Amana RFS12S COMMERCIAL MICROWAVES
Amana RFS12SW2 COMMERCIAL MICROWAVES
Amana RFS12SW2A COMMERCIAL MICROWAVES
Amana RFS18G COMMERCIAL MICROWAVES
Amana RFS18MPS COMMERCIAL MICROWAVES
Amana RFS510SE COMMERCIAL MICROWAVES
Amana RFS511 COMMERCIAL MICROWAVES
Amana RFS511MP COMMERCIAL MICROWAVES
Amana RFS511SW2 COMMERCIAL MICROWAVES
Amana RFS511SW2A COMMERCIAL MICROWAVES
Amana RFS518S COMMERCIAL MICROWAVES
Amana RFS57SE COMMERCIAL MICROWAVES
Amana RFS58MP COMMERCIAL MICROWAVES
Amana RFS58SE COMMERCIAL MICROWAVES
Amana RFS59MP COMMERCIAL MICROWAVES
Amana RFS6 COMMERCIAL MICROWAVES
Amana RFS8 COMMERCIAL MICROWAVES
Amana RFS8B COMMERCIAL MICROWAVES
Amana RFS8MP COMMERCIAL MICROWAVES
Amana RFS8MPK COMMERCIAL MICROWAVES
Amana RFS8SE COMMERCIAL MICROWAVES
Amana RFS8SW COMMERCIAL MICROWAVES
Amana RFS8SW1 COMMERCIAL MICROWAVES
Amana RFS9B COMMERCIAL MICROWAVES
Amana RFS9B2 COMMERCIAL MICROWAVES
Amana RFS9LW COMMERCIAL MICROWAVES
Amana RFS9MP COMMERCIAL MICROWAVES
Amana RFS9MP2 COMMERCIAL MICROWAVES
Amana RFS9MPH COMMERCIAL MICROWAVES
Amana RFS9MPK COMMERCIAL MICROWAVES
Amana RFS9MPLW COMMERCIAL MICROWAVES
Amana RFS9SW2 COMMERCIAL MICROWAVES
Maytag RFU1500AAW FREEZER- VERTICAL
Maytag RFU2000AAW FREEZER- VERTICAL
Maytag RFU200FAAW FREEZER- VERTICAL
Admiral RFUA120AAW FREEZER- VERTICAL
Admiral RFUA150AAW FREEZER- VERTICAL
Admiral RFUA200AAW FREEZER- VERTICAL
Admiral RFUA20FAAW FREEZER- VERTICAL
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite Water leak at filter stanward Refrigerator & Freezer Repair 0 01-03-2013 01:08 AM
Frigidaire water filter leak grijalva006 Refrigerator & Freezer Repair 2 07-19-2011 09:18 PM
Refrigerator water filter leak lpetitjean Refrigerator & Freezer Repair 0 07-18-2010 05:27 PM
Water filter leak leakyblog Refrigerator & Freezer Repair 1 11-07-2009 08:57 AM
water filter leak jtmitche Refrigerator & Freezer Repair 2 03-09-2008 11:06 AM
