Discuss
whrilpool side by side refrigerator
 in
Refrigerator & Freezer Repair
My Whirlpool side by side fridge is making a very loud clacking sound that can be stopped if you unplug
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » whrilpool side by side refrigerator
  #1 (permalink)
Old 09-26-2013, 01:06 PM
Junior Member
Linda Gream is on a distinguished road
Default whrilpool side by side refrigerator
Brand: Whirlpool   Age: 1 - 5 years
My Whirlpool side by side fridge is making a very loud clacking sound that can be stopped if you unplug a set of little wires behind a panel on the left upper inside of the fridge section. You can also see what is making the noise...a white plastic flap inside a housing located in the left upper wall of the fridge. Would unplugging and leaving upplugged this little set of colored wires cause damage until I get a repairman in to fix it....what is the problem and what does the little flap control
  #2 (permalink)
Old 09-27-2013, 04:09 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
Sounds like you may be referring to the damper.
It controls the amount of cold air that enters the fresh food side of the fridge.
Unplugging it should not damage anything.
You will have to monitor the temperature in the fresh food section so that you do not freeze things or let things get too warm.
The fresh food side should be close to 40 degrees F.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirpool side by side lights don't work in refrigerator side and also digital temp dvite Refrigerator & Freezer Repair 6 05-08-2014 11:18 AM
Whrilpool side by side jmomot Refrigerator & Freezer Repair 0 12-26-2011 07:40 AM
side by side refrigerator - fridge side freezing food, water coming out of freezer bomb Refrigerator & Freezer Repair 8 08-30-2011 02:58 PM
GE GSS25JFPAWW Side by Side Refrigerator Side Not Getting Cold TSKW914 Refrigerator & Freezer Repair 2 01-11-2011 08:09 PM
Side by Side refrigerator/freezer side not cool baq66 Refrigerator & Freezer Repair 5 08-03-2009 10:07 AM
