Hello, I have a kenmore refrigerator model 795.7102. This model has a LG liner compressor. The compressor has failed twice since 2010 when it was purchased. The first time it was replace under warranty by a Sears Tech. I bought the Frig off craigs list knowing it had a bad compressor. The compressor was not pumping, 30# back and 100# Head. I replaced the compressor. The frig cools and cycles but the voltage to the compressor runs between 210~230V. The service manual states the normal operating voltage should be between 80 and 180 volts. I am considering replacing the Compressor driver board. Before I spend the money on a new board I was hoping someone could offer some advice on how to confirm this is the problem. I am getting no error codes.
Dennis
