TOMZYBKO
#1 Posted : Sunday, February 10, 2008 2:25:00 PM(UTC)
TOMZYBKO
Every 1minute And 30 Seconds Freezer Cycles For 4 Seconds And Lighs Dim ,
kooler
#2 Posted : Monday, February 11, 2008 10:41:52 AM(UTC)
kooler
You either have a defective start relay which is an inexpensive part or a defective compressor which is expensive... Jot down the model number of your gibson and input it to the APPros parts site to identify and acquire a new start relay... If your compressor starts after replacing the relay then you may be in the clear and have your refrigerator back to normal.. Otherwise if the symptoms persist then most likely your compressor is bad... The decision to replace the compressor or the refrigerator is your next step... good luck, kooler
Electrolux fridge compartment not cooling, freezer is cold (Refrigerator & Freezer Repair)
by Minthook 4/22/2024 8:17:01 AM(UTC)
LG LMX28987ST - Motorized Freezer drawer issues (Refrigerator & Freezer Repair)
by GeriatricGinger 4/21/2024 5:27:29 AM(UTC)
KitchenAid freezer door stuck (Refrigerator & Freezer Repair)
by willeaton 4/18/2024 7:31:34 AM(UTC)
Samsung Fridge and freezer incorrect temps (Refrigerator & Freezer Repair)
by Guest 4/3/2024 9:24:02 AM(UTC)
Ice Buildup Under Freezer Platform, Leaks into Fridge (Refrigerator & Freezer Repair)
by MochaFiend 4/2/2024 3:21:56 PM(UTC)
Freezer temperature varying (Refrigerator & Freezer Repair)
by Guest 4/2/2024 6:15:22 AM(UTC)
GE Profile Freezer Wildly Varying Temps (Refrigerator & Freezer Repair)
by Guest 3/26/2024 3:54:40 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Whirlpool Gold GD5SHA Freezer Temperature Rises Overnight (Refrigerator & Freezer Repair)
by jrb98391 2/22/2024 10:20:17 AM(UTC)
Intermittent fridge/freezer (Refrigerator & Freezer Repair)
by Hystiker 2/21/2024 4:01:30 PM(UTC)
Bottom Freezer Leaking Water (Refrigerator & Freezer Repair)
by fscel 2/13/2024 11:22:53 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Whirlpool french door w/ bottom freezer (Refrigerator & Freezer Repair)
by JumperWire 2/11/2024 1:41:25 PM(UTC)
Kenmore refrigerator/freezer issue (Refrigerator & Freezer Repair)
by rgbradley58 1/30/2024 6:32:20 AM(UTC)
Frigidaire Freezer Handle (Refrigerator & Freezer Repair)
by Guest 1/21/2024 12:46:23 PM(UTC)
