I have a hotpoint side by side fridge with control panel on door a few months ago I had to shut main breaker off to do some electrical work I turned power back on the next day I realized the fridge lights where on and it was making ice but the control board was not on and the fridge was not running after messing with it almost all day I gave up and decided to call a repair man by the time I got ahold of one the fridge turned back on and started running and worked great. Yesterday the electric company came out to change a pole and transformer when they turned the power back on I now have the same issue the lights are on it makes ice but the control board is not on and fridge will not run what could be the problem? Is there some kind of defrost cycle that runs?
