Discuss
Ice maker inoperable
 in
Refrigerator & Freezer Repair
I have a TRG20SPHL Amana 20 energy saver refrigerator. The ice maker in the freezer does not produce ice. Then
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice maker inoperable
  #1 (permalink)
Old 10-10-2009, 04:17 PM
mt17249 mt17249 is offline
Junior Member
mt17249 is on a distinguished road
Default Ice maker inoperable
Model Number: TRG20SPHL   Brand: Amana   Age: 5 - 10 years
I have a TRG20SPHL Amana 20 energy saver refrigerator. The ice maker in the freezer does not produce ice. Then water line going to the fridge has water and pressure going to the fridge. It does not come out of the valve going to the ice maker. Is it common for these valves to fail? Is there a switch in the ice maker itself that shuts off this water valve that could be the problem? Any advice or help would be much appreciated.
Matt
Related Models
Amana TRG22J Ref - Top Mount
Amana TRGI18J Ref - Top Mount
Amana TRGI18QBL Ref - Top Mount
Amana TRGI18QBW Ref - Top Mount
Amana TRGI20J Ref - Top Mount
Amana TRGI22J Ref - Top Mount
Amana TRI-17D Misc / Accessory
Amana TRI-17D-1 Misc / Accessory
Amana TRI-17E Misc / Accessory
Amana TRI-17LD Misc / Accessory
Amana TRI-17LD-1 Misc / Accessory
Amana TRI-17LE Misc / Accessory
Amana TRI16K Ref - Top Mount
Amana TRI17E Misc / Accessory
Amana TRI17LE Misc / Accessory
Amana TRI18D Misc / Accessory
Amana TRI18D-A Ref - Top Mount
Amana TRI18D-C Ref - Top Mount
Amana TRI18D-G Ref - Top Mount
Amana TRI18D-L Ref - Top Mount
Amana TRI18E Misc / Accessory
Amana TRI18E-A Misc / Accessory
Amana TRI18E-C Misc / Accessory
Amana TRI18E-G Misc / Accessory
Amana TRI18E-L Misc / Accessory
Amana TRI18J Ref - Top Mount
Amana TRI18K Ref - Top Mount
Amana TRI18TE Ref - Top Mount
Amana TRI18TL Ref - Top Mount
Amana TRI18TW Ref - Top Mount
Amana TRI18V1E Ref - Top Mount
Amana TRI18V1L Ref - Top Mount
Amana TRI18V1W Ref - Top Mount
Amana TRI20K Ref - Top Mount
Amana TRI21S4E Ref - Top Mount
Amana TRI21S4L Ref - Top Mount
Amana TRI21S4W Ref - Top Mount
Amana TRI21VE Ref - Top Mount
Amana TRI21VL Ref - Top Mount
Amana TRI21VW Ref - Top Mount
Amana TRI22S4 Ref - Top Mount
Amana TRI22S4E Ref - Top Mount
Amana TRI22S4L Ref - Top Mount
Amana TRI22S4W Ref - Top Mount
Amana TRI22SRL Ref - Top Mount
Amana TRI25S5E Ref - Top Mount
Amana TRI25S5L Ref - Top Mount
Amana TRI25S5W Ref - Top Mount
Amana TRI25VE Ref - Top Mount
Amana TRI25VL Ref - Top Mount
Amana TRI25VW Ref - Top Mount
International TRIS225BAW Ref - SXS/I&W
International TRIS225FAW Ref - SXS/I&W
International TRIS245BBB Ref - SXS/I&W
International TRIS245BBW Ref - SXS/I&W
International TRIS245FBW Ref - SXS/I&W
Frigidaire TRS20WRHD0 Tap(v1) / Refrigerator
Frigidaire TRS20WRHD1 Tap(v1) / Side By Side Refrigerator
Frigidaire TRS20WRHD2 Tap(v1) / Side By Side Refrigerator
Frigidaire TRS20WRHD3 Tap(v2) / Side By Side Refrigerator
Frigidaire TRS20WRHD4 Tap(v1) / Refrigerator
Frigidaire TRS20WRHD5 Tap(v1) / Refrigerator
Frigidaire TRS20WRHW0 Tap(v2) / Refrigerator
Frigidaire TRS20WRHW1 Tap(v2) / Side By Side Refrigerator
Frigidaire TRS20WRHW2 Tap(v3) / Side By Side Refrigerator
Frigidaire TRS20WRHW3 Tap(v4) / Side By Side Refrigerator
Frigidaire TRS20WRHW4 Tap(v2) / Refrigerator
Frigidaire TRS20WRHW5 Tap(v2) / Refrigerator
Frigidaire TRS22WRAD0 Tap(v1) / Side By Side Refrigerator
Frigidaire TRS22WRAW0 Tap(v2) / Side By Side Refrigerator
Frigidaire TRS24WRAB0 Tap(v3) / Side By Side Refrigerator
Frigidaire TRS24WRAD0 Tap(v4) / Side By Side Refrigerator
Frigidaire TRS24WRAW0 Tap(v5) / Side By Side Refrigerator
Frigidaire TRS26WRAB0 Tap(v1) / Side By Side Refrigerator
Frigidaire TRS26WRAD0 Tap(v2) / Side By Side Refrigerator
Frigidaire TRS26WRAW0 Tap(v3) / Side By Side Refrigerator
Frigidaire TRT15DRAD0 Tap(v1) / Top Mount Refrigerator
Frigidaire TRT15DRAD1 Tap(v1) / Top Mount Refrigerator
Frigidaire TRT15DRAW0 Tap(v2) / Top Mount Refrigerator
Frigidaire TRT15DRAW1 Tap(v2) / Top Mount Refrigerator
Frigidaire TRT15DRCD0 Tap(v1) / Top Mount Refrigerator
Frigidaire TRT15DRCD1 Tap(v1) / Top Mount Refrigerator
Frigidaire TRT15DRCD2 Tap(v1) / Top Mount Refrigerator
Frigidaire TRT15DRCW0 Tap(v2) / Top Mount Refrigerator
Frigidaire TRT15DRCW1 Tap(v2) / Top Mount Refrigerator
Frigidaire TRT15DRCW2 Tap(v2) / Top Mount Refrigerator
Frigidaire TRT15DRCY0 Tap(v3) / Top Mount Refrigerator
Frigidaire TRT15DRCY1 Tap(v3) / Top Mount Refrigerator
Frigidaire TRT15DRCZ0 Tap(v4) / Top Mount Refrigerator
Frigidaire TRT15DRCZ1 Tap(v4) / Top Mount Refrigerator
Frigidaire TRT16NRHD0 Tap(v1) / Refrigerator
Frigidaire TRT16NRHD1 Tap(v1) / Refrigerator
Frigidaire TRT16NRHD2 Tap(v1) / Refrigerator
  #2 (permalink)
Old 10-10-2009, 04:34 PM
applianceman applianceman is offline
Senior Member
applianceman is on a distinguished road
Default
If the icemaker will cycle but you don’t get water replace the water valve. Look inside the tube that feeds water to the icemaker and make sure it isn’t clogged with ice. If it is still replace the water valve after you remove the ice. Refrigerator repair guide
  #3 (permalink)
Old 10-10-2009, 06:17 PM
Junior Member
Default
I can blow thru the line so it doesnt seems like its clogged. But isnt there something that shuts off the water when the ice maker has enough of it inside the freezer? How do i know that the water valve is shot and not anything that tells the water valve to shut off?
  #4 (permalink)
Old 10-10-2009, 09:49 PM
Senior Member
Default
Typically, if the icemaker will complete the cycle and water doesn’t enter the icemaker the water valve is bad. But yes it could still be the icemaker. I can’t exactly tell what type of icemaker your refrigerator has by the parts diagram but I am reasonably sure it is a Whirlpool type icemaker. Take the front off the icemaker and you should see holes marked with letters (if you don’t see the holes you may have a different style icemaker let me know). Make a jumper wire and place one end of the jumper wire in the hole marked L and the other in the hole marked V. This should energize the water valve. If water doesn’t enter the icemaker you can be almost positive the valve is bad. Provided you have water coming to the icemaker. Now there could still be a loose connection between the icemaker and the valve although this would be very unlikely. The only way to know for sure is to check for voltage at the water valve with the jumper in place. If you have voltage and there is no water you know for sure the valve is bad. Whirlpool Icemaker Repair Guide
  #5 (permalink)
Old 10-10-2009, 11:01 PM
Junior Member
Default
I was looking at the pic that is on this website and the watervalve looks like the one thats on the fridge. The ice maker does not have any holes marked with letters on the front. Does the valve run on straight 110V power? If that is the case I could try to make a jumper wire and run it from the wall i guess. Any other suggestions? Is there any info that i could try to find on the fridge to make this any easier?
  #6 (permalink)
Old 10-11-2009, 01:55 PM
Senior Member
Default
You could run straight from the wall but it is unnecessary and a little dangerous. If you attempt this be careful. I do not recommend doing so but it is up to you.
I was thinking that was the type icemaker you had. Ok let’s start over. I am assuming that you see two gears on the front of the icemaker. On the outside of the icemaker you should see an ejector arm that ejects the ice. Pull on that arm until the gears on the front of the icemaker start turning then you should be able to let go and the gears will continue to run. Then get behind the refrigerator and check for voltage. The water should get voltage for the last few seconds of the icemaker cycle. If it does get voltage and water doesn’t flow replace the water valve. If it doesn’t get voltage replace the icemaker.
If you don’t have a voltage tester just replace the water valve if the icemaker will cycle.
  #7 (permalink)
Old 10-11-2009, 08:33 PM
Junior Member
Default
I do see two gears on the outside of the ice maker and an ejector arm. I rotate and pull on that are an nothing happens. I have seen the ice maker rotate before thou. It has done it a couple times since ive been messing with it, but seems random. I took the front panel with the gears off and looked around in there. If i pull that arm towards me it doesnt look like that would do anything except compress the return spring. Is it supposed to hit a switch of some sort? When you say "pull on that arm", do you mean pull towards me or rotate it the way the arm is moved when ejecting ice or turning off the icemaker? When i rotate that arm then bring it back down, is the icemaker supposed to turn to eject ice?
  #8 (permalink)
Old 10-12-2009, 07:23 AM
Senior Member
Default
With the gears on and the icemaker back together rotate the ejector arm as if the icemaker was going through a cycle. Once you turn it manually a little it should start turning on its own.
Reading your post I am not 100% sure we are talking about the same arm. I am talking the white arm the forces the ice out the ice mold. Not the little wire is on the side of the icemaker that goes up and down. Just making sure!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE tube ice maker freezing but ice maker works dhayden Refrigerator & Freezer Repair 1 09-05-2009 09:54 AM
Replaced Ice Maker and noid and still no water to ice maker darrewhite Refrigerator & Freezer Repair 0 05-17-2009 07:34 AM
GE Microwave Vent fan/lights inoperable firefler Microwave Repair 4 12-15-2008 08:26 AM
dishwasher door latch inoperable reggie knowles Dishwasher Repair 7 11-14-2008 08:29 AM
Top stove burners inoperable. hgriffin Oven Repair (including Ranges and Cooktops) 1 10-15-2008 01:27 PM
