The dispenser panel has no power. I checked the voltage (13VDC) at the connector at the base of the freezer door and it was good. I then checked at the connector to the dispenser circuit board and no voltage is there. I then did a continuity test from the connector going into the bottom of the door to where the wires come out at the dispenser and there was no continuity on the positive line. What bothers me is the wires going in the door are different then the wires going out. it looks like my only choice is to remove the freezer door liner, but I don't see any screws. Does anyone know how to remove the liner, or could offer any other advise?
