I am trying to determine how to check compressor board. Service manual states to check voltage on con201 terminals capacitor and power after 30 seconds of power on and it should be around 200v, i get 245v. looks like in manual says to disconnect con201 and check voltage after powering on, when i check voltage on con201 unplugged i get no voltage. which way is correct and is the 245v to much? thanks for any help.
