Based on initial frozen fin area behind bottom freezer and force defrost doing nothing....I ordered and replaced the heater evaporator and heater thermostat. Turned on refrigerator...Freezer cooling (10 degrees after 3.5 hrs with the fridge area not receiving any cooling) There is no air flow from the damper even though it's open.
I ran through the service test and could not detect any sound when in test 3...toggle evaporator/freezer fan on/off...OTHER THAN TEST THREE all others seem okay.
Any next step help is appreciated!
ps....I'm not sure how to stay in contact when receiving help??? THANKS!
