Discuss
Amana side by side not freezing
 in
Refrigerator & Freezer Repair
Hi, My fridge stopped working properly yesterday morning. Things in freezer started to melt. It was 99 degrees F yesterday
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana side by side not freezing
  #1 (permalink)
Old 08-27-2013, 01:25 PM
Junior Member
mjp0074 is on a distinguished road
Default Amana side by side not freezing
Model Number: sxd22s2w   Brand: Amana   Age: More than 10 years
Hi, My fridge stopped working properly yesterday morning. Things in freezer started to melt. It was 99 degrees F yesterday here.
I cleaned the condensor coils under the fridge. They were very dirty and hot. I removed the evaporator coil cover and there is only ice/frost near the top and around an apparent blue sensor. The evaporator fan is blowing. The condensor/compressor fan in the back near the bottom is not running. The compressor is hot to the touch. I can't really feel a vibration, but can detect one with a stethoscope. The condensor coils were hot last night and I cleaned them and have a house fan blowing on them. The fridge seems to be getting progressively worse. What do you think this is going on with it? Is it done?
Mike
Related Models
Amana SXD22S2W REF - SXS/I&W
Amana SXD23VE REF - SXS/I&W
Amana SXD23VL REF - SXS/I&W
Amana SXD23VW REF - SXS/I&W
Amana SXD25AE REF - SXS/I&W
Amana SXD25AL REF - SXS/I&W
Amana SXD25AW REF - SXS/I&W
Amana SXD25J REF - SXS/I&W
Amana SXD25JB REF - SXS/I&W
Amana SXD25JP REF - SXS/I&W
Amana SXD25M2L REF - SXS/I&W
Amana SXD25M2W REF - SXS/I&W
Amana SXD25MB2L REF - SXS/I&W
Amana SXD25MB2W REF - SXS/I&W
Amana SXD25MBG REF - SXS/I&W
Amana SXD25MBL REF - SXS/I&W
Amana SXD25MBW REF - SXS/I&W
Amana SXD25MG REF - SXS/I&W
Amana SXD25ML REF - SXS/I&W
Amana SXD25MP2L REF - SXS/I&W
Amana SXD25MP2W REF - SXS/I&W
Amana SXD25MPG REF - SXS/I&W
Amana SXD25MPL REF - SXS/I&W
Amana SXD25MPW REF - SXS/I&W
Amana SXD25MW REF - SXS/I&W
Amana SXD25N2E REF - SXS/I&W
Amana SXD25N2L REF - SXS/I&W
Amana SXD25N2W REF - SXS/I&W
Amana SXD25NE REF - SXS/I&W
Amana SXD25NL REF - SXS/I&W
Amana SXD25NP2E REF - SXS/I&W
Amana SXD25NP2L REF - SXS/I&W
Amana SXD25NP2W REF - SXS/I&W
Amana SXD25NPE REF - SXS/I&W
Amana SXD25NPL REF - SXS/I&W
Amana SXD25NPW REF - SXS/I&W
Amana SXD25NW REF - SXS/I&W
Amana SXD25QA3E REF - SXS/I&W
Amana SXD25QA3L REF - SXS/I&W
Amana SXD25QA3W REF - SXS/I&W
Amana SXD25S2E REF - SXS/I&W
Amana SXD25S2L REF - SXS/I&W
Amana SXD25S2W REF - SXS/I&W
Amana SXD26VE REF - SXS/I&W
Amana SXD26VL REF - SXS/I&W
Amana SXD26VW REF - SXS/I&W
Amana SXD27NE REF - SXS/I&W
Amana SXD27NL REF - SXS/I&W
Amana SXD27NW REF - SXS/I&W
Amana SXD27Q2E REF - SXS/I&W
Amana SXD27Q2L REF - SXS/I&W
Amana SXD27Q2W REF - SXS/I&W
Amana SXD27TE REF - SXS/I&W
Amana SXD27TL REF - SXS/I&W
Amana SXD27TW REF - SXS/I&W
Amana SXD322L REF - SXS/I&W
Amana SXD322S2L REF - SXS/I&W
  #2 (permalink)
Old 08-28-2013, 03:45 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for SXD22S2W - AppliancePartsPros.com
If the compressor is running then the condenser fan should also be running as they are wired in parallel.
Check to see if there is 120 volts across the condenser fan.
If not then odds are that the compressor is not running.
__________________
  #3 (permalink)
Old 08-28-2013, 01:48 PM
Junior Member
Default can't get at fan terminals
hi, I removed the fan but the terminals aren't accessible. It seems to be hardwired and plug into the compressor and that itself is very hard to get at. There is a warning to not have power and compressor terminal cover removed. When i plugged it back in the compressor seems to run. I can feel it vibrating and get hot but compressor fan is dead. Also when i opened the freezer this morning the evaporator coils were frosted up almost halfway down. The compressor fan motor gets hot but won't turn on its own. The condenser coils were not very warm almost room temp. does the compressor not work if the fan burns out? What next?
  #4 (permalink)
Old 08-28-2013, 02:32 PM
Junior Member
Default
Hi, well i pulled the wires out of the condenser fan, plugged fridge in, and tested the voltage. It was 123 V. So do you think compressor is toasted now? Did it overheat when it was 100F with no fan?
  #5 (permalink)
Old 08-29-2013, 03:44 AM
Senior Expert
APP Volunteer
Default
No the compressor will still work if the fan is bad but it will get hot and the unit will struggle to maintain the freezer temperature since air is not circulating over the condenser coils.
Was the unit running with the evaporator cover off?
Partial freezing of the evaporator coil is an indication of a sealed system problem often low freon.
You have to be careful as to when you check them because if you check them shortly after or during a defrost cycle you could come to the wrong conclusion.
The condenser/compressor fan needs replacing.
Possible but I doubt it as it is still running.
The compressor does have overheat protection so if it gets too hot it would have shut off. Then when it cooled down some it would start up again since it is still pretty warm it would turn off again after a short time. You probably would have noticed this rapid cycling.
If you have a floor fan etc you could direct it at the machine compartment so you get air flow through it. Then if the unit runs OK you know that the unit just needs a condenser fan.
Make sure that the cover in the freezer is installed. After about 10 hours the freezer should get down to about 0 to 5 degrees F but depanding on the ambient temperature this could take longer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Side-by-side fridge freezing foods on the side next to the freezer araratjan Refrigerator & Freezer Repair 1 01-08-2013 03:40 AM
Artica side by side is freezing fresh food side crazeemomof3 Refrigerator & Freezer Repair 0 01-05-2013 05:51 PM
Amana side by side refrigerator side is freezing bsgcjg Refrigerator & Freezer Repair 3 10-19-2011 12:18 PM
side by side refrigerator - fridge side freezing food, water coming out of freezer bomb Refrigerator & Freezer Repair 8 08-30-2011 01:58 PM
Amana side by side freezer not freezing. kate91 Refrigerator & Freezer Repair 0 06-01-2011 08:01 AM
