Techdad1954
#1 Posted : Friday, October 9, 2009 4:17:59 PM(UTC)
Techdad1954
I have a front roller broken and the thing is fixed in place with a brass pin to the sheet metal and I'm stumped as how this is removed. I have replaced the evaperator motor and icemaker recently and the compressor has the famous Sears thump with the broken spring,but this roller issue has stumped me big time and no it don't just wiggle out after you remove the front screws...HELP!!!!!
Techdad1954
#2 Posted : Friday, October 16, 2009 10:36:59 AM(UTC)
Techdad1954
Anyone have a clue?
Techdad1954
#3 Posted : Sunday, November 1, 2009 2:19:07 PM(UTC)
Techdad1954
The best way I found was to drill a hole on the outside about half inch in dia. straight from the pin and it will push out, install a new one and fill the hole with a little liquid foam and hope your lucky enough it's in a place which does not show. Hope this helps someone else in the future it's not that bad with a little skill.
