Original symptoms: Ice make would not fill with water and stuck in Harvest mode
Testing done: -Optics test and received two flashes -Tested water inlet valve with ohmmeter and one pump was good while the other was dead.
Troubleshooted: -Heated water line leading to freezer with blow dryer for 20 min. -Did same to where water exits nozzle inside freezer in ice maker tray -Unplugged refrigerator for 5 seconds and got it out of harvest mode.
Parts replaced: -Replaced both optics boards initially before becoming familiar with how to troubleshoot ice maker -Replaced water inlet valve
Any help would be appreciated.
Thanks, Dave
