I have a Gladiator (made by Whirlpool) refrigerator/freezer model # GARF19xxPK01. it seems like the ref is getting stuck in the defrost mode, it will run cold then several days later the temp is up and the ice is melting then it will run cold again. The repairman replaced the control panel part # WPL2304099 and the same thing happened with the new part. He is thinking about replacing the thermostat part # WPL2254102. Any ideas? Thanks for your help
