Wild ill
#1 Posted : Tuesday, August 20, 2013 1:55:36 PM(UTC)
Wild ill
Refrigerator would cool good but would not cycle on and off. Compressor would run all the time and temp would go to below zero. Only way to turn off was to turn t/s to off. Finally just let run and finally shut down and started defrost mode I assume. Stayed in defrost mode and I finally unplugged unit.
#2 Posted : Wednesday, August 21, 2013 2:48:36 AM(UTC)
What is the freezer temperature?
Wild ill
#3 Posted : Wednesday, August 21, 2013 2:57:28 AM(UTC)
Wild ill
Freezer was -2 degrees. I have decided that I have a bad thermostat which I have ordered. I also have ordered a defrost timer just in case I need it. Only thing I need now is a hint how to get the plastic cover removed where the thermostat is located. I only found one clip on left side bottom which I have removed.
#4 Posted : Wednesday, August 21, 2013 3:24:48 AM(UTC)
Try a hair dryer on the plastic parts.
GE Refrigerator DFE29JSDASS (Dishwasher Repair)
by DOUGZARA Today at 9:43:25 AM(UTC)
Electrolux Refrigerator not getting cold (Refrigerator & Freezer Repair)
by jesus freak 3/30/2024 1:11:55 AM(UTC)
Kitchenaid Refrigerator Ice chute frosting up and clogging (Refrigerator & Freezer Repair)
by Guest 3/26/2024 9:05:12 AM(UTC)
Built-In Kitchenaid Mdel KSSC42QMS00 Refrigerator (Refrigerator & Freezer Repair)
by Guest 3/25/2024 6:29:18 AM(UTC)
Samsung Refrigerator - Service Kit for Icing Issue (Refrigerator & Freezer Repair)
by keith1386 3/24/2024 8:57:57 AM(UTC)
Automatic water filter bypass - Whirlpool Refrigerator GD5SHAXLQ02 (Refrigerator & Freezer Repair)
by z-vap 2/28/2024 2:08:23 PM(UTC)
Maytag Refrigerator freezing food on lowest setting (Refrigerator & Freezer Repair)
by ilgy 2/15/2024 8:14:17 AM(UTC)
EA120 EA150 Bosch Error Code - Built In Refrigerator (Refrigerator & Freezer Repair)
by Peter Franks 2/13/2024 4:55:41 PM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Kenmore refrigerator/freezer issue (Refrigerator & Freezer Repair)
by rgbradley58 1/30/2024 6:32:20 AM(UTC)
Power Surge damage to Refrigerator and Clothes Drier (Refrigerator & Freezer Repair)
by CBorucki 1/21/2024 7:29:43 AM(UTC)
Frigidaire Refrigerator model 253.56602402 issue (Refrigerator & Freezer Repair)
by anitak4242 1/17/2024 8:32:53 PM(UTC)
Whirlpool Refrigerator question (Dishwasher Repair)
by staffx4 1/9/2024 11:15:21 AM(UTC)
Frigidaire Gallery Refrigerator GRFS2853AF4 - Freezer not working (Refrigerator & Freezer Repair)
by Repaircat 1/9/2024 8:08:53 AM(UTC)
Frigidaire Refrigerator FRS24XGCB1 (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:18:22 PM(UTC)
