Hi
Have a kitchen aid Fridge that is leaking from the water dispenser. Shut off water supply to the unit and the leak is gone. Everything else in the fridge works perfectly (freezer, fridge all fully functional. Want to reconnect the water to dispenser and ice maker. What would make the dispenser leak into the evaporation / defrost pan underneath.
How do I trace the leak and replace / fix the problem
Dwinx
