1 week ago my ice machine stopped producing ice, went into defrost and the clean light began blinking steadily. I cleaned the machine as I have done several times prior with the solution and it ran without problems. I turned my machine to on about 48 hours ago and have yet to receive any ice. The water fills the reservoir and it appears to be making ice, then about 20 minutes later the water drains out and fills back up again. I am not familiar with the workings of the ice machine, but it seems like most major components are working properly. The inside of the machine is cold. Any help is greatly appreciated.
