hfguyton
#1 Posted : Friday, August 9, 2013 8:09:18 AM(UTC)
hfguyton
When I run the service test for the defrost thermostat, it shows that the thermostat is closed (shorted) -- I replaced the thermostat and it showed open -- a few days later it is back to closed. Is it ever normal for it to be closed -- if so, in what situation. The refrigerator seems to run too much sometimes -- and normal other times. I can't see any frost building up -- just don't understand the significance of the code. Thanks.
#2 Posted : Saturday, August 10, 2013 1:14:07 AM(UTC)
Yes closed is normal.
I cannot confirm the below but this is the norm for most units.
The defrost cycle time is a fixed time usually about 30 minutes.
The defrost thermostat should be closed when frozen. It opens just above freezing. It is wired in series with the defrost heater.
So lets say a defrost cycle starts the heater heats up as the defrost thermostat is closed. But lets also say that all the ice/frost is melted off the evaporator coils after 15 minutes. The defrost thermostat opens killing power to the heater. This prevents extra unneeded heat from getting into the freezer during defrost. The defrost cycle then continues for another 15 minutes but the heater will be off.
I cannot say why the unit seems to vary the run times.
Check the door and seals.
Looks like the unit has an energy switch. Check that someone in the household is not turning it on/off.
Check/clean the condenser/compressor coils under the unit. Also the vents in the kick plate and rear cover.
Check that the condenser/compressor fan is running at the same speed all the time.
Most of the above should effect the unit all the time.
Intermittant problems are a pain.
You may want to get a couple thermometers so you can monitor the freezer and fresh food compartment temperatures. Could be that the unit is varying the temperatures and/or set points.
Automatic water filter bypass - Whirlpool Refrigerator GD5SHAXLQ02 (Refrigerator & Freezer Repair)
by z-vap 2/28/2024 2:08:23 PM(UTC)
Whirlpool Refrigerator question (Dishwasher Repair)
by staffx4 1/9/2024 11:15:21 AM(UTC)
Whirlpool Refrigerator WSF26C2EXY02 (Refrigerator & Freezer Repair)
by DLanier 12/4/2023 5:06:34 AM(UTC)
Whirlpool Refrigerator Issue (Refrigerator & Freezer Repair)
by jrbentley 11/5/2023 1:04:02 PM(UTC)
Whirlpool Refrigerator Model WSF26C2EXF01 not making ice. (Refrigerator & Freezer Repair)
by agarcia5 8/26/2023 4:53:02 PM(UTC)
Whirlpool Refrigerator Model ED25TEXHW01 (Refrigerator & Freezer Repair)
by jammer48 8/18/2023 1:05:09 PM(UTC)
Whirlpool Refrigerator cooling intermittently or not cooling at all (Refrigerator & Freezer Repair)
by lsitnj 8/12/2023 3:39:26 PM(UTC)
Whirlpool Refrigerator inside lights, ice and water dispenser doesn't work (Refrigerator & Freezer Repair)
by Guest 1/6/2023 5:15:20 PM(UTC)
Whirlpool Refrigerator making a rather odd noise (Refrigerator & Freezer Repair)
by dbdata 12/7/2022 9:55:57 AM(UTC)
Whirlpool refrigerator water dispensing issue (Refrigerator & Freezer Repair)
by andymayor 7/6/2022 2:22:17 PM(UTC)
Whirlpool refrigerator replacement ice maker (Refrigerator & Freezer Repair)
by MELLIOTT 6/9/2022 9:06:52 AM(UTC)
Whirlpool refrigerator Model Number et1mtkxkq07 (Refrigerator & Freezer Repair)
by Guest 5/13/2022 1:16:28 AM(UTC)
Whirlpool refrigerator won’t freeze (Refrigerator & Freezer Repair)
by Nick72 5/12/2022 7:37:51 AM(UTC)
Whirlpool Refrigerator GD5SHAXLQ02 - Door not dispensing ice (Refrigerator & Freezer Repair)
by z-vap 3/21/2022 5:33:58 AM(UTC)
Whirlpool Refrigerator Freezer Coils Icing up (Refrigerator & Freezer Repair)
by aarrington 2/25/2022 5:39:48 AM(UTC)
