I replaced my electronic control board due to some issues that I was having. At first everything started working OK then I got a Door Ajar alarm and then the light stopped working. So I decided to order a new door switch from you which I just installed. Once again everything started working OK again then about 15 mins later the alarm came on and the light stopped working as well. I decided to check the switch I replaced and there is nothing wrong with it. Now what? What else could be the problem? It seems like it's the electronic board but I just replaced it.
