Discuss
Is this compressor bad or not?
 in
Refrigerator & Freezer Repair
Compressor, good or bad, 14.3 ohm's across bottom two pins, 10.9 ohm's between top pin and bottom left, 4.0 ohm's
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Is this compressor bad or not?
  #1 (permalink)
Old 07-24-2013, 11:01 AM
Junior Member
dclange is on a distinguished road
Default Is this compressor bad or not?
Model Number: RT18AKXKQ05   Brand: Roper   Age: 5 - 10 years
between top pin and bottom left, 4.0 ohm's between top pin and bottom right. Is this compressor good or bad? Tested all pins for a short to ground, all pins read 0 ohm's. Start device/relay combo rattles allot. No continuity between the two holes and 0 ohm's also. This is bad right? Frig was making clicking noises, light and condenser fan work. What do you guy's think?
Related Models
Roper RT18AKXKQ05 REFRIGERATOR
Roper RT18AKXKQ06 REFRIGERATOR
Roper RT18AKXKQ07 REFRIGERATOR
Roper RT18AKXKQ08 REFRIGERATOR
Roper RT18AKXKQ09 REFRIGERATOR
Roper RT18AKXKQ70 REFRIGERATOR
Roper RT18AKXKT00 TOP-MOUNT REFRIGERATOR
Roper RT18AKXKT01 TOP-MOUNT REFRIGERATOR
Roper RT18AKXKT02 TOP-MOUNT REFRIGERATOR
Roper RT18AKXKT03 TOP-MOUNT REFRIGERATOR
Roper RT18AKXKT04 REFRIGERATOR
Roper RT18AKXKT05 REFRIGERATOR
Roper RT18AKXXW00 Refrigerator
Roper RT18AKXXW01 Refrigerator
Roper RT18AKXZW00 Refrigerator
Roper RT18BKXAW00 Refrigerators
Roper RT18BKXAW01 REFRIGERATOR
Roper RT18BKXBL00 REFRIGERATOR
Roper RT18BKXBL01 REFRIGERATOR
Roper RT18BKXBW00 REFRIGERATOR
Roper RT18BKXBW01 REFRIGERATOR
Roper RT18BKXDN00 REFRIGERATOR
Roper RT18BKXDN01 REFRIGERATOR
Roper RT18BKXDN03 REFRIGERATORS
Roper RT18BKXDW00 REFRIGERATOR
Roper RT18BKXDW01 REFRIGERATOR
Roper RT18BKXDW03 REFRIGERATORS
Roper RT18BKXEN01 REFRIGERATOR
Roper RT18BKXEW01 REFRIGERATOR
Roper RT18BKXJW00 TOP-MOUNT REFRIGERATOR
Roper RT18BKXKQ00 REFRIGERATOR
Roper RT18BKXKQ01 REFRIGERATOR
Roper RT18BKXKQ02 REFRIGERATOR
Roper RT18BKXKQ03 REFRIGERATOR
Roper RT18BKXKZ00 REFRIGERATOR
Roper RT18BKXKZ01 REFRIGERATOR
Roper RT18BKXSQ00 REFRIGERATOR
Roper RT18BKXWW00 Refrigerators
Roper RT18BKXWW01 Refrigerators
Roper RT18BKXXW00 Refrigerators
Roper RT18BMXAW00 Refrigerators*
Roper RT18BMXAW01 REFRIGERATOR
Roper RT18BMXBL00 REFRIGERATOR
Roper RT18BMXBL01 REFRIGERATOR
Roper RT18BMXBW00 REFRIGERATOR
Roper RT18BMXBW01 REFRIGERATOR
Roper RT18BMXDN00 REFRIGERATOR
Roper RT18BMXDW00 REFRIGERATOR
Roper RT18BMXVW00 Refrigerators*
Roper RT18BMXVW01 Refrigerators*
Roper RT18BMXVW03 Refrigerators*
Roper RT18BMXVW05 Refrigerators*
Roper RT18BMXVW10 Refrigerators*
Roper RT18BMXVW11 Refrigerators*
Roper RT18BMXXW00 Refrigerators*
Roper RT18DKXAL01 REFRIGERATOR
Roper RT18DKXAL02 REFRIGERATOR
Roper RT18DKXAW00 Refrigerators*
Roper RT18DKXAW01 REFRIGERATOR
Roper RT18DKXAW02 REFRIGERATOR
Roper RT18DKXBL01 REFRIGERATOR
Roper RT18DKXBL10 REFRIGERATOR
Roper RT18DKXBL20 REFRIGERATOR
Roper RT18DKXBW00 Refrigerators*
Roper RT18DKXBW01 REFRIGERATOR
Roper RT18DKXBW10 REFRIGERATOR
Roper RT18DKXBW20 REFRIGERATOR
Roper RT18DKXDN10 REFRIGERATOR
Roper RT18DKXDN20 TOP MOUNT REFRIGERATOR
Roper RT18DKXDW10 REFRIGERATOR
Roper RT18DKXDW20 TOP MOUNT REFRIGERATOR
Roper RT18DKXEN00 TOP MOUNT REFRIGERATOR
Roper RT18DKXEN01 TOP MOUNT REFRIGERATOR
Roper RT18DKXEN03 REFRIGERATORS
Roper RT18DKXEN04 TOP MOUNT REFRIGERATOR
Roper RT18DKXEN05 REFRIGERATOR
Roper RT18DKXEW00 TOP MOUNT REFRIGERATOR
Roper RT18DKXEW01 TOP MOUNT REFRIGERATOR
Roper RT18DKXEW03 REFRIGERATORS
Roper RT18DKXEW04 TOP MOUNT REFRIGERATOR
Roper RT18DKXEW05 REFRIGERATOR
Roper RT18DKXFN00 REFRIGERATOR
Roper RT18DKXFN01 REFRIGERATOR
Roper RT18DKXFN02 REFRIGERATOR
Roper RT18DKXFN03 REFRIGERATOR
Roper RT18DKXFN04 REFRIGERATOR
Roper RT18DKXFW00 REFRIGERATOR
Roper RT18DKXFW01 REFRIGERATOR
Roper RT18DKXFW02 REFRIGERATOR
Roper RT18DKXFW03 REFRIGERATOR
Roper RT18DKXFW04 REFRIGERATOR
Roper RT18DKXHN00 REFRIGERATOR
Roper RT18DKXHN01 REFRIGERATOR
Roper RT18DKXHW00 REFRIGERATOR
Roper RT18DKXHW01 REFRIGERATOR
Roper RT18DKXJN00 REFRIGERATOR
Roper RT18DKXJN01 TOP-MOUNT REFRIGERATOR
Roper RT18DKXJW00 REFRIGERATOR
Roper RT18DKXJW01 TOP-MOUNT REFRIGERATOR
Roper RT18DKXKQ00 TOP-MOUNT REFRIGERATOR
Roper RT18DKXKQ01 TOP-MOUNT REFRIGERATOR
Roper RT18DKXKQ02 TOP-MOUNT REFRIGERATOR
Roper RT18DKXKQ03 TOP-MOUNT REFRIGERATOR
Roper RT18DKXKQ04 REFRIGERATOR
Roper RT18DKXKQ05 REFRIGERATOR
Roper RT18DKXKQ06 REFRIGERATOR
Roper RT18DKXKQ07 REFRIGERATOR
Roper RT18DKXKQ08 REFRIGERATOR
Roper RT18DKXKQ09 REFRIGERATOR
Roper RT18DKXKT00 TOP-MOUNT REFRIGERATOR
Roper RT18DKXKT01 TOP-MOUNT REFRIGERATOR
Roper RT18DKXKT02 TOP-MOUNT REFRIGERATOR
Roper RT18DKXKT03 TOP-MOUNT REFRIGERATOR
Roper RT18DKXKT04 REFRIGERATOR
Roper RT18DKXKT05 REFRIGERATOR
Roper RT18DKXKT06 REFRIGERATOR
Roper RT18DKXKT07 REFRIGERATOR
Roper RT18DKXKT08 REFRIGERATOR
Roper RT18DKXKT09 REFRIGERATOR
Roper RT18DKXWW00 Refrigerators*
  #2 (permalink)
Old 07-25-2013, 02:39 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Ohm readings will not show burnt windings. Best to just replace the start device with a new one, probably will fix it.
__________________
  #3 (permalink)
Old 07-25-2013, 07:04 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
FYI. may be just semantics but
0 ohms is a dead short circuit re: no resistance at all.
infinite (no) ohms is an open circuit re: there is no circuit path.
__________________
  #4 (permalink)
Old 07-25-2013, 01:53 PM
Junior Member
Default
Thanks for the replies! Richappy, I guess your saying the compressor could still be bad? I also tested for continuity between all the pins and they all have continuity. Denman, when I tested for a short, here is what I did. I put one test lead on each pin one at a time and the other test lead on the ground terminal of the compressor housing. I think maybe I stated my readings wrong when I said they each read 0 ohm's. I had the meter set to read ohm's, but the meter did not register anything on any of the pins. The screen did not read like 0.0, it was blank. Did I state that wrong I guess? Open and closed circuits always confuse me. Throwing short circuit and infinite in there makes it worse. I always thought that a closed circuit let current thru, and a open circuit did not, correct? Anyway, ordered the start device and will put it on and see if it works when I get it. Will let you guy's know if it works or not. Thanks for helping a guy that knows just enough to be dangerous!
  #5 (permalink)
Old 07-25-2013, 02:17 PM
Senior Expert
APP Volunteer
Default
Yes.
In this case richappy knew what you meant but if you had given the same info just with different words then the conclusion would have been that the compressor is toast re: shorted out.
You are correct so I am not sure why you are confused.
If you hold both meter leads apart, this is an obvious open circuit and no current will flow. Your meter will not give a resistance reading (infinite ohms).
Now if you short the meter leads together, this is an obvious short circuit and maximum current will flow. Your meter shows 0 ohms which is zero resistance to current flow.
Hopefully the new start device will do the trick. I will keep my fingers crossed.
__________________
  #6 (permalink)
Old 07-27-2013, 01:09 PM
Junior Member
Default
Ok guys, got start device yesterday, and put it on, plugged in frig, compressor took right running. Set dial to coldest setting 9 and put thermometer in the freezer compartment. Checked 6 hours later, -10 degrees! Let run over night, still -10 this morning, so turned the dial down to 5 normal setting. Checked again about 5 hours later, up to 20 degrees. Walked around back, could hear compressor trying to kick in and out. Felt compressor and it was pretty hot, so unplugged it to let it cool down. Going to try to plug it back in later when cool. Oh, I still have the cardboard off of the back of frig. Would that make the air circulation that bad to cause the compressor to get hot? Are is this compressor shot? Bad run windings or something? Help again, please?
  #7 (permalink)
Old 07-29-2013, 05:00 AM
Senior Expert
APP Volunteer
Default
Goods idea as it does sound like the compressor overheated.
Could be that it was just working too hard trying ro reach a low set point.
Yes it could but normally there is enough cooling so that the compressor does not overheat. I am assuming that the condenser fan was running anfd that it was still pushing lots of air.
Yes it could be a bad compressor.
I would not trust this unit.
__________________
  #8 (permalink)
Old 07-29-2013, 08:00 PM
Junior Member
Default
Ok, tried three times plugging in frig when cold, compressor runs great, takes freezer temp down to -10 set on the middle setting of 3. After two or three hours the compressor starts that click-short hum-off deal about every 8 to 10 seconds. Unplug it, let it set a while and cool down, starts, runs great, till to starts it's click deal.
I did not replace the little overload when I replaced the start device relay. Should I have replaced that also? Could the overload be bad, keeping it from starting when the compressor is warm? Any way to test the overload with a meter? I have another overload on another frig, that sure looks like the same part, don't know if part numbers match, could I try a swap, maybe? Just hard to believe the compressor is bad when it gets the frig that cold.
  #9 (permalink)
Old 07-30-2013, 03:29 AM
Senior Expert
APP Volunteer
Default
See the attachment for the wiring diagram.
Below is a link with info on how to test the overload.
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
Short your meter leads together before testing it so you can see if the meter has a zero offset.
If there is some resistance then replace it.
This would cause a voltage drop across it when the compressor is on so that the compressor gets a lower voltage and that can cause it to overheat.
It does sound like the overload is doing it's job of stopping the compressor from running when it is too hot so if the overload is OK then all that is left is a bad compressor.
If your compressor uses a run capacitor then that may also be a problem but the parts breakdown does not show one so I doubt you have one.
__________________
  #10 (permalink)
Old 07-30-2013, 12:06 PM
Junior Member
Default
When I short the meter leads together I get a zero offset of 0.01 When I put the leads across the overload terminals I get 0.03 . I have another frig with the same type/shape overload that runs fine. Tested that overload just to see if the readings were the same, it was 0.03 also. From the wiring diagram it says the compressor run windings should be between 1-6 ohm's resistance (mine are 3.6) and that the start windings should be between 3-11 ohm's resistance (mine are 10.5) I think my problem is with that reading, it's to high, that the start windings are burnt something. Letting it start when cold, but not when warm or hot. Plus the start and run ohm's resistance total of 13.9 doesn't equal. (10.5 + 3.6 = 14.1) The other (good) frig compressor tested 4.2 on run winding and 6.4 on start winding and a total across run and start of 10.6 that is equal (4.2 + 6.4 = 10.6). I think my start windings has something wrong with them. So, I'm ready to give in. Going to call AmerenUE to pick it up, they give you $50 if it is running. Not going to plug it in till the day they are coming to pick it up. Then I'll pull the start device before they load it up and get my money back for that part. All I'm out is my time then. Denman I want to thank you for all your help. You save allot of people allot of money. We appreciate it. I can see from your 15K plus posts you have been at it awhile. Keep sharing your knowledge, the world is a better place for it. PS: Your correct, the frig has no cap.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer warm, clicking noise from compressor, compressor very hot sgtmajor58 Refrigerator & Freezer Repair 1 08-08-2009 06:57 PM
Compressor and Compressor Fan Not Working sdowns Refrigerator & Freezer Repair 0 05-02-2009 08:08 PM
frig and freezer warm,clicking noisefrom compressor,compressor very hot tdot Refrigerator & Freezer Repair 4 04-02-2008 08:35 AM
