Discuss
Kenmore Elite Trio Freezer Light
 in
Refrigerator & Freezer Repair
The light stopped working in the freezer section - the bulb was ok. Took a blow dryer on cool setting
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore Elite Trio Freezer Light
  #1 (permalink)
Old 07-22-2013, 06:51 AM
Junior Member
sbly is on a distinguished road
Default Kenmore Elite Trio Freezer Light
Brand: Kenmore   Age: 5 - 10 years
The light stopped working in the freezer section - the bulb was ok. Took a blow dryer on cool setting to the switch and bulb section in case of condensation and put the bulb back in and it worked again. After the freezer section got cold again, the light stopped working again. As long as the dial is set to 0 in the freezer section the light stays on, but when set to the mid-range after a while the light stops working again.
  #2 (permalink)
Old 07-23-2013, 05:24 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I am not sure what type of bulb/receptacle you have as you did not include a model number.
If it is a standard incandescent bulb then try the following.
Unplug the unit.
Remove the bulb.
Look into the receptacle and you will see the center connector for the bulb.
Bend that up a bit.
Be gentle as they can snap off easily also be sure that you do not bend it over to the side.
Also check that the connector is clean.
__________________
  #3 (permalink)
Old 07-23-2013, 06:03 AM
Junior Member
Default Kenmore Elite Trio freezer light
Model number is 596.73503200 and we did bend up the receptacle part but after the freezer gets cold the light no longer works.
Unplug the unit.
Remove the bulb.
Bend that up a bit.
  #4 (permalink)
Old 07-24-2013, 04:11 AM
Senior Expert
APP Volunteer
Default
Something is contracting when the unit gets cold and is causing an open circuit.
Did you try a different bulb?
If you have the I would check/replace the light switch.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite Trio. Lights will not come on... JMCFAN Refrigerator & Freezer Repair 5 07-23-2013 06:14 AM
Kenmore Elite TRIO - Icemaker Gears Freezing up JDish Refrigerator & Freezer Repair 1 03-15-2013 08:12 AM
Kenmore Elite Trio not cooling or freezing dart79 Refrigerator & Freezer Repair 2 01-27-2011 07:59 AM
Kenmore Elite Trio aquario3 Refrigerator & Freezer Repair 0 10-05-2010 04:57 PM
Kenmore Elite Trio MHome Refrigerator & Freezer Repair 1 04-19-2009 03:15 PM
