Discuss
Kenmore Freezer Problem
 in
Refrigerator & Freezer Repair
Hi, we have a Kenmore model# 25326442100 freezer that worked great until we had a power brown out where the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore Freezer Problem
  #1 (permalink)
Old 07-22-2013, 07:14 AM
Junior Member
cover is on a distinguished road
Default Kenmore Freezer Problem
Model Number: 25326442100   Brand: Kenmore   Age: 1 - 5 years
Hi, we have a Kenmore model# 25326442100 freezer that worked great until we had a power brown out where the voltage dropped to about 80vac until it was corrected.
An online Sears wrote: "
Check the defrost timer. Manually advance the defrost timer with the knob to see if turns the freezer on. The defrost time is located in the outside back of the freezer. If the freezer turns on you have a bad timer. You can also disconnect the timer and jump two wires to turn on freezer. You need a wire diagram of your freezer. Usually white and yellow or yellow and blue. This will activate the cooling cycle. Low voltage can destroy ac motors and compressors. I would check the winding in the compressor. Check your main thermostat. "
And though my freezer is indeed frost free, I can't find the "defrost timer" that he refers to. I'm kind of stuck in that space where I'm trying to explore the inexpensive options toward fixing this freezer before I just go buy another one so as not to have any expensive service call only to have to do a major purchase afterward. So does anyone know more about this defrost timer location for this particular model, by chance? TIA
Related Models
Kenmore 25326442100 FREEZER
Kenmore 25326442101 FREEZER
Kenmore 25326452100 FREEZER
Kenmore 25326452101 FREEZER
Kenmore 25326458100 FREEZER
Kenmore 25326458101 FREEZER
Kenmore 25326462100 FREEZER
Kenmore 25326462101 FREEZER
Kenmore 25326468100 FREEZER
Kenmore 25326468101 FREEZER
Kenmore 25326472100 FREEZER
Kenmore 25326472101 FREEZER
Kenmore 25326472102 FREEZER
Kenmore 25326482100 FREEZER
Kenmore 25326482101 FREEZER
Kenmore 25326482102 FREEZER
Kenmore 25326722100 FREEZER
Kenmore 25326722101 FREEZER
Kenmore 25326722102 FREEZER
Kenmore 25326722103 FREEZER
Kenmore 25326722104 FREEZER
Kenmore 25326732100 FREEZER
Kenmore 25326732101 FREEZER
Kenmore 25326732102 FREEZER
Kenmore 25326732103 FREEZER
Kenmore 25326732104 FREEZER
Kenmore 25326742100 FREEZER
Kenmore 25326742101 FREEZER
Kenmore 25326742102 FREEZER
Kenmore 25326742103 FREEZER
Kenmore 25326742104 FREEZER
Kenmore 25326752100 FREEZER
Kenmore 25326762100 FREEZER
Kenmore 25327042700 FREEZER
Kenmore 25327042701 FREEZER
Kenmore 25327042702 FREEZER
Kenmore 25327042703 FREEZER
Kenmore 25327042704 FREEZER
Kenmore 25327042705 FREEZER
Kenmore 25327202700 FREEZER
Kenmore 25327422700 FREEZER
Kenmore 25327422701 FREEZER
Kenmore 25327422702 SEARS/FREEZER 0582
Kenmore 25328042800 FREEZER
Kenmore 25328042801 FREEZER
Kenmore 25328042802 FREEZER
Kenmore 25328042803 FREEZER
Kenmore 25328042804 FREEZER
Kenmore 25328042805 FREEZER
Kenmore 25328042807 FREEZER
Kenmore 25328052800 FREEZER
Kenmore 25328052801 FREEZER
Kenmore 25328052802 FREEZER
Kenmore 25328052803 FREEZER
Kenmore 25328052805 FREEZER
Kenmore 25328052806 FREEZER
Kenmore 25328052807 FREEZER
Kenmore 25328052808 FREEZER
Kenmore 25328062800 FREEZER
Kenmore 25328062801 FREEZER
Kenmore 25328092800 FREEZER
Kenmore 25328092801 FREEZER
Kenmore 25328092802 FREEZER
Kenmore 25328092803 FREEZER
Kenmore 25328092805 FREEZER
Kenmore 25328093800 FREEZER
Kenmore 25328093801 FREEZER
Kenmore 25328093802 FREEZER
Kenmore 25328093803 FREEZER
Kenmore 25328099800 FREEZER
Kenmore 25328099801 FREEZER
Kenmore 25328099802 FREEZER
Kenmore 25328099803 SEARS/FREEZER 0583
Kenmore 25328099805 FREEZER
Kenmore 25328262800 FREEZER
Kenmore 25328262801 FREEZER
Kenmore 25328262802 FREEZER
Kenmore 25328262803 FREEZER
Kenmore 25328262804 FREEZER
Kenmore 25328262805 FREEZER
Kenmore 25328272801 FREEZER
Kenmore 25328421890 UPRIGHT FREEZER
Kenmore 25328432800 FREEZER
Kenmore 25328432801 FREEZER
Kenmore 25328432802 FREEZER
Kenmore 25328432803 FREEZER
Kenmore 25328432804 FREEZER
Kenmore 25328432805 FREEZER
Kenmore 25328432806 FREEZER
Kenmore 25328432807 FREEZER
Kenmore 25328432808 FREEZER
Kenmore 25328432809 FREEZER
Kenmore 25328442800 FREEZER
Kenmore 25328442801 FREEZER
Kenmore 25328452801 FREEZER
Kenmore 25328452802 FREEZER
Kenmore 25328452803 FREEZER
Kenmore 25328452804 FREEZER
Kenmore 25328452805 FREEZER
Kenmore 25328452806 FREEZER
Kenmore 25328452807 FREEZER
Kenmore 25328452808 FREEZER
Kenmore 25328459800 FREEZER
Kenmore 25328459801 FREEZER
Kenmore 25328459802 FREEZER
Kenmore 25328459803 FREEZER
Kenmore 25328459804 FREEZER
Kenmore 25328459805 FREEZER
Kenmore 25328459806 FREEZER
Kenmore 25328459807 FREEZER
Kenmore 25328459808 FREEZER
Kenmore 25328459809 FREEZER
Kenmore 25328459810 FREEZER
Kenmore 25328462801 FREEZER
Kenmore 25328469801 FREEZER
Kenmore 25328712800 FREEZER
Kenmore 25328712801 FREEZER
Kenmore 25328712802 FREEZER
Kenmore 25328712803 FREEZER
Kenmore 25328712804 FREEZER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Upright Fridge/Freezer - Freezer not cold enough gstump Refrigerator & Freezer Repair 6 06-13-2012 02:51 PM
Problem with Kenmore elite fridge freezer marlenehadge@gmail.com Refrigerator & Freezer Repair 0 09-01-2010 02:59 PM
Kenmore Elite Freezer Problem - Not Cold Enough rtmorris00 Refrigerator & Freezer Repair 2 06-11-2010 06:06 PM
Kenmore Key Pad Problem prodigerati Dishwasher Repair 1 01-14-2010 08:54 PM
Freezer problem pmik33 Refrigerator & Freezer Repair 0 04-06-2008 07:45 PM
