Have a Marvel 30iMAT under the counter icemaker. Have cleaned the evaporator plate and distributor tube--a few times. Water runs over the plate, the plate gets frosty, the water stops running over the plate, the harvest cycle begins and melts the frost away. No ice cubes are forming. It seems to be cycling okay. Any suggestions/help is appreciated. Thanks!
