Discuss
Black oil like substance leaking from bottom left side
 in
Refrigerator & Freezer Repair
Woke up with oil leak on floor. Motor? Ads By Google Related Models Kenmore  25312021101  FREEZER Kenmore  25312541100  FREEZER Kenmore
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Black oil like substance leaking from bottom left side
  #1 (permalink)
Old 10-08-2009, 07:31 AM
Junior Member
SandyV48 is on a distinguished road
Default Black oil like substance leaking from bottom left side
Model Number: 253/970   Brand: Sears   Age: 5 - 10 years
Ads By Google
Related Models
Kenmore 25312541102 SEARS/FREEZER
Kenmore 25312551100 FREEZER
Kenmore 25313051100 FREEZER
Kenmore 25313312101 FREEZER
Kenmore 25313351100 FREEZER
Kenmore 25313541101 FREEZER
Kenmore 25313551100 FREEZER
Kenmore 25313711100 FREEZER
Kenmore 25313712100 FREEZER
Kenmore 25313911100 FREEZER
Kenmore 25318331002 CHEST FREEZER
Kenmore 25318331890 CHEST FREEZER
Kenmore 25318331891 CHEST FREEZER
Kenmore 25318351004 CHEST FREEZER
Kenmore 25318351005 FREEZER
Kenmore 25318351006 FREEZER
Kenmore 25319321002 CHEST FREEZER
Kenmore 25319321003 FREEZER
Kenmore 25319321004 CHEST FREEZER
Kenmore 25319321990 CHEST FREEZER
Kenmore 25319321991 FREEZER
Kenmore 25319331000 CHEST FREEZER
Kenmore 25319501990 CHEST FREEZER
Kenmore 25319501991 FREEZER
Kenmore 25319501992 FREEZER
Kenmore 25319531003 CHEST FREEZER
Kenmore 25319531990 CHEST FREEZER
Kenmore 25319531991 CHEST FREEZER
Kenmore 25319531994 CHEST FREEZER
Kenmore 25319531995 FREEZER
Kenmore 25319701990 CHEST FREEZER
Kenmore 25319701991 FREEZER
Kenmore 25319821004 CHEST FREEZER
Kenmore 25319821990 CHEST FREEZER
Kenmore 25319821991 CHEST FREEZER
Kenmore 25319821992 FREEZER
Kenmore 25319821995 CHEST FREEZER
Kenmore 25321201100 FREEZER
Kenmore 25321201102 FREEZER
Kenmore 25321211100 UPRIGHT FREEZER
Kenmore 25321211101 FREEZER
Kenmore 25321401100 FREEZER
Kenmore 25321401101 FREEZER
Kenmore 25321402100 FREEZER
Kenmore 25321402101 FREEZER
Kenmore 25321402102 FREEZER
Kenmore 25321402103 FREEZER
Kenmore 25321411100 FREEZER
Kenmore 25321411101 FREEZER
Kenmore 25321411102 FREEZER
Kenmore 25321411103 FREEZER
Kenmore 25321411104 FREEZER
Kenmore 25321421100 FREEZER
Kenmore 25321421101 FREEZER
Kenmore 25321421102 FREEZER
Kenmore 25321421103 FREEZER
Kenmore 25321421104 FREEZER
Kenmore 25321421105 FREEZER
Kenmore 25321711100 FREEZER
Kenmore 25321711101 FREEZER
Kenmore 25321711102 FREEZER
Kenmore 25321711103 FREEZER
Kenmore 2532230 AIR CLEANERS/DEODORIZERS
Kenmore 25322401100 FREEZER
Kenmore 25322401101 SEARS/FREEZER
Kenmore 25322402100 FREEZER
Kenmore 25322411100 FREEZER
Kenmore 25322411101 FREEZER
Kenmore 25322411102 SEARS/FREEZER
Kenmore 25323024100 FREEZER
Kenmore 25323082100 FREEZER
Kenmore 25323114100 FREEZER
Kenmore 25323414100 FREEZER
Kenmore 25323424100 FREEZER
Kenmore 25323425100 FREEZER
Kenmore 25323714100 FREEZER
Kenmore 25323724100 FREEZER
Kenmore 25323725100 FREEZER
Kenmore 25329082990 UPRIGHT FREEZER
Kenmore 25329082991 UPRIGHT FREEZER
Kenmore 25329082992 FREEZER
Kenmore 25329082993 FREEZER
Kenmore 25329082994 FREEZER
Kenmore 25329101990 UPRIGHT FREEZER
Kenmore 25329101992 UPRIGHT FREEZER
Kenmore 25329101993 FREEZER
Kenmore 25329101994 UPRIGHT FREEZER
Kenmore 25329111990 UPRIGHT FREEZER
Kenmore 25329111991 FREEZER
Kenmore 25329111992 UPRIGHT FREEZER
Kenmore 25329121990 UPRIGHT FREEZER
Kenmore 25329201000 UPRIGHT FREEZER
Kenmore 25329201001 UPRIGHT FREEZER
Kenmore 25329201002 UPRIGHT FREEZER
Kenmore 25329401990 UPRIGHT FREEZER
Kenmore 25329401991 FREEZER
Kenmore 25329401992 UPRIGHT FREEZER
Kenmore 25329711990 UPRIGHT FREEZER
Kenmore 25329711991 FREEZER
Kenmore 25329711992 UPRIGHT FREEZER
Kenmore 25331113300 REFRIGERATOR
Kenmore 25331115300 REFRIGERATOR
Kenmore 25331123300 REFRIGERATOR
Kenmore 25331125300 REFRIGERATOR
Kenmore 25331133300 REFRIGERATOR
Kenmore 25331135300 REFRIGERATOR
Kenmore 25331143300 REFRIGERATOR
Kenmore 25331145300 REFRIGERATOR
Kenmore 25336600890 TOP MOUNT REFRIGERATOR
Kenmore 25336600891 TOP MOUNT REFRIGERATOR
Kenmore 25336600892 TOP MOUNT REFRIGERATOR
Kenmore 25336600894 TOP MOUNT REFRIGERATOR
Kenmore 25336600895 TOP MOUNT
Kenmore 25336600896 REFRIGERATOR
Kenmore 25336600898 TOP MOUNT REFRIGERATOR
Kenmore 25336601890 TOP MOUNT REFRIGERATOR
Kenmore 25336601891 TOP MOUNT REFRIGERATOR
Kenmore 25336601892 TOP MOUNT REFRIGERATOR
  #2 (permalink)
Old 10-08-2009, 07:45 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Your Model Number is incorrect, please check it.
The only thing with oil in it, in a fridge is the motor.
So if it came from the fridge you have a major problem.
I would shut off the unit till you can determine the source.
__________________
  #3 (permalink)
Old 10-08-2009, 08:38 AM
Junior Member
Default Model # from Sears Manual 253 or 970
Label inside door is Model 253-73754302.
Thanks. I am sure it's MAJOR!
  #4 (permalink)
Old 10-08-2009, 08:43 AM
Junior Member
Default Motor?
Model Sears Kenmore 253-73754302. No motor shown in the schematic. I suspect going to get a new refrig shortly.
Thanks!
  #5 (permalink)
Old 10-08-2009, 10:52 AM
Senior Expert
APP Volunteer
Default
You had said motor so I used the same terminology actually it is an oil filled compressor.
__________________
  #6 (permalink)
Old 10-08-2009, 12:06 PM
Junior Member
Scadaboy is on a distinguished road
Unhappy Black stuff is likely
It is possible your compressor is overheating and the shell is oozing its bonding/sealing gasket material becaue of the heat. The lubricating oil could also be leaking out a bad gasket. It is either failing on its own, or a continuous call for cooling (stuck thermostat or dirty coils) is making it run too much. There is usually a thermal limit switch built in to the compressor which is likely bad in addition to the other things. (This would allow it overheat).
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
soap suds are left in the bottom of the dishwasher faiths1 Dishwasher Repair 1 11-08-2009 04:25 AM
Dishes have a black tar like substance mwlong Dishwasher Repair 0 10-24-2009 04:14 PM
GE side by side refrig tfh22prsm ww leaking from bottom, no longer cold either side thomashaskins Refrigerator & Freezer Repair 3 09-13-2009 07:01 PM
Dishes not clean gritty black stuff left behind meyergr Dishwasher Repair 4 02-25-2009 03:45 PM
Washer sometimes leaks bottom front left liseglaz Washer Repair 0 02-02-2008 08:38 AM
