Discuss
Kitchen Aid Fridge cycles often
 in
Refrigerator & Freezer Repair
Measure the freezer and fridg. temperatures before it shuts off. Also, if you set the control to a lower temperature,
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kitchen Aid Fridge cycles often
  #21 (permalink)
Old 09-13-2013, 01:27 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Also, if you set the control to a lower temperature, does it reach a lower temperature and run longer?
__________________
  #22 (permalink)
Old 09-18-2013, 02:33 PM
Junior Member
harley4850 is on a distinguished road
Default
Fridge side 40 deg. when it starts running. After it shuts off 10 mins later, its at 33. Freezer at about 5 degrees. When it shuts off. about -2 degrees. Lowered the fridge and freezer temps, no change in cycle times. 10 on 10 off.
  #23 (permalink)
Old 09-19-2013, 01:32 AM
Senior Expert
APP Volunteer
Default
Are you sure you placed the fridg cold control sensing tubing in the original place? Seems like you have no basic refrigeration system problems, but a control problem.
__________________
  #24 (permalink)
Old 09-19-2013, 01:15 PM
Junior Member
Default
Yes. I'm sure. My initial thought was that it had a bad thermostat, so I replaced it. Same results. I know its possible to have a new one be bad. Is there any way to test them? I still have the old one so it is easy to access and test.
  #25 (permalink)
Old 09-20-2013, 01:23 AM
Senior Expert
APP Volunteer
Default
Turn the cold control to the coldest setting, then measure the freezer temperature, should go well below zero, if not you do have refrigeration systems problems that gauges would confirm.
You also could have a stuck damper door.
__________________
  #26 (permalink)
Old 09-20-2013, 10:38 PM
Junior Member
Default
I will try those things. If I'm not mistaken, the damper door is manual that works off the freezer control slide. At least that is what I saw when I took it apart to install the thermostat. Not sure how it could stick?
  #27 (permalink)
Old 09-23-2013, 06:57 PM
Junior Member
Default
Hey Rich,
I ran the cold control as cold as it would go. The freezer went well below zero. My digital gauge wouldn't read at that cold as it blacked out. My analog does not read below zero, but it buried the needle. If I were to gauge it according to the distance of the other marks on the gauge, I would say it was way more than -20 or better. Once the system shut off, it went to defrost. I did this 2 times and both times it went to the defrost cycle.
Thanks.
  #28 (permalink)
Old 09-24-2013, 01:28 AM
Senior Expert
APP Volunteer
Default
Only thing left is too much cold air into the fridg section. You might try a partial restriction of the airflow into the fridg.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchen Aid D/W has very long cycles GNACK Dishwasher Repair 0 05-24-2013 08:29 AM
Kitchen Aid Gas Broiler Cycles On and Off pastacheph Oven Repair (including Ranges and Cooktops) 0 05-25-2012 10:03 AM
Fridge cycles quickly on/off then on again Jack Smith Refrigerator & Freezer Repair 2 02-04-2011 09:20 AM
Kitchen aid 3 cycle light and cycles not working javierr Dishwasher Repair 0 08-19-2009 02:09 PM
Kitchen Aid Fridge KSCS25FKSS00 is freezing on the fridge size shawnharper Refrigerator & Freezer Repair 0 09-03-2007 10:27 PM
