Water will not flow into the ice maker. It was working fine but suddenly stopped working. I checked the water supply and the water is turned on and the hose line is not kinked. Something is stopping the water flow at the entrance to the ice maker. I was told that it could be a solinoid problem but I don't know where they are located or how to check them out. I need your help in this matter.
