| » GE Refrigerator water not flowing from dispenser |
Model Number: gsl22jftabs Brand: GE Age: 1 - 5 years
Last week wasn't getting any water flow from water dispenser so i replaced it with new water filter. Then i had water flow. Now this week there is no water flow at all. And i was wondering could it be the water flow pump in this particular model that needs replacing.
Often on this model the water line will freeze in the freezer door. Remove the coupling from the bottom of the freezer door and see if you get water there when you attempt to use the water dispenser. If water does come once you disconnect the coupling the line is frozen. To fix this open the door and press the door switch. Then repeatedly press the dispenser lever until you get water.
IF you don’t get water when you take the coupling loose the valve may be your problem. This page may help GE Refrigerators Repair Guide |
| Display Modes | |
| Fresh Water not flowing and Ice Melting | lukehutsell | Refrigerator & Freezer Repair | 1 | 11-16-2009 09:28 PM |
| Refrigerator Water Line Repair for Ice/Water Dispenser | jodijo1968 | Refrigerator & Freezer Repair | 1 | 08-21-2009 07:08 AM |
| water leak in front of refrigerator when using water dispenser | RichardCh | Refrigerator & Freezer Repair | 0 | 08-10-2009 10:29 AM |
| Water flowing into freezer | marc7 | Refrigerator & Freezer Repair | 3 | 02-09-2009 12:59 PM |
| water dispenser/water keeps flowing | markshigemi | Refrigerator & Freezer Repair | 0 | 06-12-2008 05:17 AM |
