The seal on the upper corner of lower freezer door is not "sealing"--and as a result ice chips form on the inside.
I changed the door gasket but the problem persists.
I suspect that the hardware that supports the door--the sliding metal hardware may have worn out or become bent somewhat.
i need help troubleshooting-- which part i would need to repair this or ??
