I replaced the compressor using the kit which included a dryer. According th the diagram I have the lines connected correctly. It is an Embraco EGX 70HLC with the process line on the left and the larger suction line and discharge on the right.
Problem is high pressure, 100 lb, on the process line and low pressure on the dryer side connection.
Jim
