Discuss
**Frigidaire double door not dispensing water or making ice
 in
Refrigerator & Freezer Repair
Ok I searched for this issue but none of what I have found pertains to my problem. At the dispenser
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » **Frigidaire double door not dispensing water or making ice
  #1 (permalink)
Old 06-28-2013, 06:43 PM
Junior Member
Cheeva316 is on a distinguished road
Default **Frigidaire double door not dispensing water or making ice
Model Number: FES26IHDS0   Brand: Frigidaire   Age: 5 - 10 years
At the dispenser when I push the lever, the vavle on the back kicks on but no water comes out , below the door when disconnected no water comes out.
back of fridge:
water is going in from my home water line to the first valve.
water is going out to the fridge through the water line from the first valve.
now the line that comes back down from the fridge to the rear valve>no water comes out.
Inside the fridge side:
if I take the filter housing off and push the water lever water spits out in very good pressure.
So it seems water is going into the filter assembly in the fridge side but water is not circulating back out the filter housing assembly down the fridge to the rear valve.
Also I tested this with 2 different valve assemblies and both did the same thing.
Could the water filter assembly be plugged up or gone bad?
Cause there is not water going into the ice maker either.
DOes the filter assembly push water out or does something pull water from the filter assembly??
thanks in advance.
Related Models
Frigidaire FES300ASA Frigidaire/electric Range
Frigidaire FES300ASB Frigidaire/electric Range
Frigidaire FES300ASC Frigidaire/electric Range
Frigidaire FES300ASD Frigidaire/electric Range
Frigidaire FES300ASE Frigidaire/electric Range
Frigidaire FES300ASF Frigidaire/electric Range
Frigidaire FES300BEBA Frg(v0) / Electric Range
Frigidaire FES300BEBB Frg(v0) / Electric Range
Frigidaire FES300BEBC Frg(v0) / Electric Range
Frigidaire FES300DSA Frigidaire/electric Range
Frigidaire FES300DSB Frigidaire/electric Range
Frigidaire FES300EBA Frigidaire/electric Range
Frigidaire FES300EBB Frigidaire/electric Range
Frigidaire FES300EBC Frigidaire/range
Frigidaire FES300EBD Frigidaire/electric Range
Frigidaire FES300EBE ELECTRIC RANGE
Frigidaire FES300ESA Frigidaire/electric Range
Frigidaire FES300ESB Frigidaire/electric Range
Frigidaire FES300ESC Frigidaire/range
Frigidaire FES300ESD Frigidaire/electric Range
Frigidaire FES300WAB1 Frg(v6) / Electric Range
Frigidaire FES300WAB3 Frg(v1) / Electric Range
Frigidaire FES300WABA Frg(v3) / Electric Range
Frigidaire FES300WABC Frg(v2) / Electric Range
Frigidaire FES300WAD1 Frg(v5) / Electric Range
Frigidaire FES300WAD3 Frg(v3) / Electric Range
Frigidaire FES300WADA Frg(v2) / Electric Range
Frigidaire FES300WADC Frg(v4) / Electric Range
Frigidaire FES300WAW1 Frg(v4) / Electric Range
Frigidaire FES300WAW3 Frg(v5) / Electric Range
Frigidaire FES300WAWA Frg(v1) / Electric Range
Frigidaire FES300WAWC Frg(v6) / Electric Range
Frigidaire FES300WCD1 Frg/electric Range
Frigidaire FES300WCD2 Frg/electric Range
Frigidaire FES300WCDA Frg/electric Range
Frigidaire FES300WCDB Frg/electric Range
Frigidaire FES300WCDC Frg/electric Range
Frigidaire FES300WCDD Frg(v1) / Electric Range
Frigidaire FES300WCDE Frg/electric Range
Frigidaire FES300WCDF Frg/electric Range
Frigidaire FES300WCDG Frg(v1) / Electric Range
Frigidaire FES300WCDH Frg(v1) / Electric Range
Frigidaire FES300WCDI Frg(v1) / Electric Range
Frigidaire FES300WCW1 Frg/electric Range
Frigidaire FES300WCW2 Frg/electric Range
Frigidaire FES300WCWA Frg/electric Range
Frigidaire FES300WCWB Frg/electric Range
Frigidaire FES300WCWC Frg/electric Range
Frigidaire FES300WCWD Frg(v2) / Electric Range
Frigidaire FES300WCWE Frg/electric Range
Frigidaire FES300WCWF Frg/electric Range
Frigidaire FES300WCWG Frg(v2) / Electric Range
Frigidaire FES300WCWH Frg(v2) / Electric Range
Frigidaire FES300WCWI Frg(v2) / Electric Range
Frigidaire FES300WCWJ El Slide - in Fes300wcwj Frigidaire
Roper FES310BL0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES310BL1 30" ELECTRIC FREESTANDING SELF-CLEAN RANGE
Roper FES310BQ0 30" ELECTRIC FREE STANDING SELF CLEAN RANGE
Roper FES310BQ1 30" ELECTRIC FREESTANDING SELF-CLEAN RANGE
Roper FES310BW0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES310BW1 30" ELECTRIC FREESTANDING SELF-CLEAN RANGE
Roper FES310YW0 ELECTRIC RANGE
Roper FES310YW1 ELECTRIC RANGE
Roper FES310YW2 ELECTRIC RANGE
Roper FES325RQ0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES325RQ1 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES325RQ2 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES326RD0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES330EN0 ELECTRIC RANGES AND OVENS
Roper FES330EQ0 ELECTRIC RANGES AND OVENS
Roper FES330EW0 ELECTRIC RANGES AND OVENS
Roper FES330GN0 30" ELECTRIC FREESTANDING SELF-CLEAN RANGE
Roper FES330GN1 ELECTRIC RANGE
Roper FES330GQ0 30" ELECTRIC FREESTANDING SELF-CLEAN RANGE
Roper FES330GQ1 ELECTRIC RANGE
Roper FES330GW0 30" ELECTRIC FREESTANDING SELF-CLEAN RANGE
Roper FES330GW1 ELECTRIC RANGE
Roper FES330KN0 ELECTRIC RANGE
Roper FES330KN1 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES330KQ0 ELECTRIC RANGE
Roper FES330KQ1 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES330KW0 ELECTRIC RANGE
Roper FES330KW1 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES340VL0 ELECTRIC SELF-CLEANING OVEN
Roper FES340VW0 ELECTRIC SELF-CLEANING OVEN
Roper FES340VW1 Ranges, Electric*
Roper FES340VX0 ELECTRIC SELF-CLEANING OVEN
Roper FES340YW0 Ranges, Electric*
Roper FES340YW1 Ranges, Electric*
Roper FES340YW2 Ranges, Electric*
 FES350BL0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
 FES350BL1 30" ELECTRIC FREE-STANDING SELF-CLEAN RANGE
 FES350BW0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
 FES350BW1 30" ELECTRIC FREE-STANDING SELF-CLEAN RANGE
Frigidaire FES353CCD1 Frg/electric Wall Oven
Frigidaire FES353CCD2 Frg(v1) / Electric Range
Frigidaire FES353CCDA Frg/electric Range
Frigidaire FES353CCDB Frg(v2) / Electric Range
Frigidaire FES353CCDC Frg(v1) / Electric Range
Frigidaire FES353CCDD Frg(v1) / Electric Range
Frigidaire FES353CCDG Frg(v1) / Electric Range
Frigidaire FES353CCW1 Frg/electric Wall Oven
Frigidaire FES353CCW2 Frg(v3) / Electric Range
Frigidaire FES353CCWA Frg/electric Wall Oven
Frigidaire FES353CCWB Frg(v4) / Electric Range
Frigidaire FES353CCWC Frg(v2) / Electric Range
Frigidaire FES353CCWD Frg(v2) / Electric Range
Frigidaire FES353CCWG Frg(v2) / Electric Range
Frigidaire FES354BAB1 Frg(v2) / Electric Range
Frigidaire FES354BAB3 Frg(v0) / Electric Range
Frigidaire FES354BABA Frg(v1) / Electric Range
Frigidaire FES354BABC Frg(v0) / Electric Range
Frigidaire FES355ABA Frigidaire/electric Range
Frigidaire FES355ABB Frigidaire/electric Range
Frigidaire FES355ABC Frigidaire/electric Range
Frigidaire FES355ABD Frigidaire/electric Range
Frigidaire FES355ABE Frigidaire/electric Range
Frigidaire FES355ABF Frigidaire/electric Range
Frigidaire FES355ASA Frigidaire/electric Range
Frigidaire FES355ASB Frigidaire/electric Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile not making ice or dispensing water blackstone Refrigerator & Freezer Repair 0 01-29-2012 08:07 AM
refridgerator making ice but not dispensing water jd61497 Refrigerator & Freezer Repair 3 12-06-2011 06:27 AM
Refrigerator not dispensing water or making ice jamesjlaw Refrigerator & Freezer Repair 1 02-06-2010 05:54 PM
Refridgerator nor dispensing water or making ice gerardo Refrigerator & Freezer Repair 2 03-28-2009 08:43 AM
Frigidaire-no ice dispensing, no water dispensing FixingIt Refrigerator & Freezer Repair 2 08-25-2008 12:32 PM
