enduringlion
#1 Posted : Friday, June 28, 2013 11:58:47 AM(UTC)
enduringlion
Can any one tell me what the continuity should be for the thermistors in the freezer. There are 2 of them, one is located at the bottom of the freezer and the other is attached to the top of the evaporator. The evaporator is freezing up and I have isolated the defrost time and it tested good 0.0 ohms. I have also test the defrost element which read 26.5 ohms which I believe is good as well. I would like to test the thermistor but I don't have or know what they should read at various temps or room temp.:confused:
#2 Posted : Friday, June 28, 2013 12:49:24 PM(UTC)
Test the evaporator thermistor right on the motherboard Ji- pin4 to J1- pin 5
should be around 65 kohm at -13 degrees. If way off value, replace it.
I posted more info at the sticky above.
