Discuss
Refrigerator Side of Side By Side Not Cooling
 in
Refrigerator & Freezer Repair
Amana side by side purchased in 1997. Problem: Refrigerator side not cooling below 40 degrees. Additional info: When temp control
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator Side of Side By Side Not Cooling
  #1 (permalink)
Old 06-15-2013, 06:51 PM
Junior Member
tlcmd is on a distinguished road
Default Refrigerator Side of Side By Side Not Cooling
Model Number: SRD25S5L   Brand: Amana   Age: More than 10 years
Additional info: When temp control turned fully to lowest temp, freezer side cools to about 1 (one) degree but frig side will not cool below 39 at best.
Seals are good, vacuum sucks when opening either side door.
Frig has sealed door compartment with separate cold air input which will hold a gallon of milk OJ, etc and this gets cold enough to put ice on top of the milk.
We've defrosted the frig with everything out for 4+ hours with no change. Also blown and vacuumed out the coils.
My diagnosis is that the "fresh food" Thermostatic control unit is not working. As I understand it, this control mechanically controls a damper between the freezer and the fresh food compartments. I think that isn't working or is stuck. I do feel some cool air blowing from it, but not a lot so I believe the fan is working, especially since the door sealed compartment on the fresh food side does get to around 32 degrees.
MY QUESTION: How do i remove the cover of the thermostatic control to check the status of this damper? Any other suggestions?
This unit has outlived its expected lifespan, so hate to spend the money for a service call which could go toward a new comparable side by side unit if this is a "Mickey Mouse" fix I can do. I do have 2 left hands and 5 thumbs on each one.
My wife has pretty much decided to replace this old beastie, I'm willing to make this simple check if appropriate before we give up and go buy a new one for at least a grand plus.
Thanks for any advice, comments, and snide remarks..even.
tlcmd
Related Models
Amana SRD25S5L REF - SXS/I&W
Amana SRD25S5W REF - SXS/I&W
Amana SRD25TPE REF - SXS/I&W
Amana SRD25TPL REF - SXS/I&W
Amana SRD25TPSE REF - SXS/I&W
Amana SRD25TPW REF - SXS/I&W
Amana SRD25VPE REF - SXS/I&W
Amana SRD25VPL REF - SXS/I&W
Amana SRD25VPSE REF - SXS/I&W
Amana SRD25VPW REF - SXS/I&W
Amana SRD26VE REF - SXS/I&W
Amana SRD26VL REF - SXS/I&W
Amana SRD26VPE REF - SXS/I&W
Amana SRD26VPSE REF - SXS/I&W
Amana SRD26VW REF - SXS/I&W
Amana SRD27S2E REF - SXS/I&W
Amana SRD27S2L REF - SXS/I&W
Amana SRD27S2W REF - SXS/I&W
Amana SRD27S4E REF - SXS/I&W
Amana SRD27S4L REF - SXS/I&W
Amana SRD27S4W REF - SXS/I&W
Amana SRD27TPE REF - SXS/I&W
Amana SRD27TPSE REF - SXS/I&W
Amana SRD27TPW REF - SXS/I&W
Amana SRD325S5E REF - SXS/I&W
Amana SRD325S5L REF - SXS/I&W
Amana SRD325S5W REF - SXS/I&W
Amana SRD327S3L REF - SXS/I&W
Amana SRD327S3W REF - SXS/I&W
Amana SRD520SE REF - SXS/I&W
Amana SRD520SL REF - SXS/I&W
Amana SRD520SW REF - SXS/I&W
Amana SRD520TE REF - SXS/I&W
Amana SRD520TW REF - SXS/I&W
Amana SRD522SW REF - SXS/I&W
Amana SRD522TE REF - SXS/I&W
Amana SRD522TW REF - SXS/I&W
Amana SRD522VE REF - SXS/I&W
Amana SRD522VW REF - SXS/I&W
Amana SRD526SL REF - SXS/I&W
Amana SRD526SW REF - SXS/I&W
Amana SRD526TW REF - SXS/I&W
Amana SRD528VE REF - SXS/I&W
Amana SRD528VW REF - SXS/I&W
Amana SRDE25TE REF - SXS/I&W
Amana SRDE25TPE REF - SXS/I&W
Amana SRDE25TPSE REF - SXS/I&W
Amana SRDE25TPW REF - SXS/I&W
Amana SRDE25TW REF - SXS/I&W
Amana SRDE27S3E REF - SXS/I&W
Amana SRDE27S3L REF - SXS/I&W
Amana SRDE27S3W REF - SXS/I&W
Amana SRDE27TPE REF - SXS/I&W
Amana SRDE27TPSE REF - SXS/I&W
Amana SRDE27TPW REF - SXS/I&W
Amana SRDE327S3E REF - SXS/I&W
Amana SRDE327S3L REF - SXS/I&W
Amana SRDE327S3W REF - SXS/I&W
Amana SRDE520SBW REF - SXS/I&W
Amana SRDE520SW REF - SXS/I&W
  #2 (permalink)
Old 06-16-2013, 07:02 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Remove the back, freezer panel and describe the frost pattern, all coils should be covered with light frost. Wet, and stick your finger on the evaporator coils. Should stick to the coils at the top and bottom. If you have a spot thermometer, measure the temperature in the middle of the evaporator.
__________________
  #3 (permalink)
Old 06-16-2013, 10:00 AM
Junior Member
Default We've done that
Thanks!
We have removed the back and all the coils were cold with a light covering of frost. I think the probem is in the passage of the cold air from the freezer through to the fresh food section.
I believe I need to be able to get into the thermostat itself. How do I remove the cover??
tlcmd
  #4 (permalink)
Old 06-17-2013, 02:33 AM
Senior Expert
APP Volunteer
Default
Check the damper door and air returns on the bottom.
__________________
  #5 (permalink)
Old 06-17-2013, 02:45 AM
Junior Member
Default
Thanks for the reply, but I told you i had 2 left hands and 10 thumbs. How do I get to the damper door on this model?. I suspect it is through the thermostatic control box on the back of the fresh food compartment at the top. If so, how do i remove that box cover? If not, how do I get to that damper door? I can rebuild a 4 barrel Rochester carb and rebuild a 454 GMC truck motor and cure Rocky Mountain Spotted Fever (I'm an MD), but not a frig guru.
Thanks,
tlcmd
  #6 (permalink)
Old 06-17-2013, 11:02 AM
Senior Expert
APP Volunteer
Default
Not familiar with your model, but there must be a screw holding the cover on and tabs on the cover that go in slots in the side wall.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Gallery Series Side by Side Refrigerator Not Cooling affordableappliances1 Refrigerator & Freezer Repair 1 05-10-2013 02:41 AM
Side by Side Kitchenaid Superba Refrigerator not cooling HomeRepairer7 Refrigerator & Freezer Repair 1 07-29-2012 04:02 AM
Frigidire refrigerator side by side stopped cooling nejin Refrigerator & Freezer Repair 2 03-25-2012 02:48 AM
GE side by side refrigerator - upper half not cooling and no ice cubes or water ngarey Refrigerator & Freezer Repair 0 09-13-2011 02:01 PM
side by side refrigerator stopped cooling and freezing bbcowboy Refrigerator & Freezer Repair 3 03-21-2008 07:02 PM
