Discuss
Kenmore Upright Freezer Will Not Get cool or cold
 in
Refrigerator & Freezer Repair
2000 Kenmore Upright Freezer. Worked fine. Parents moved to an assisted living apt in Jan 2012. Freezer was unplugged and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore Upright Freezer Will Not Get cool or cold
  #1 (permalink)
Old 06-15-2013, 05:58 AM
Junior Member
Vol Fan is on a distinguished road
Default Kenmore Upright Freezer Will Not Get cool or cold
Model Number: 253.9287413   Brand: Sears   Age: More than 10 years
2000 Kenmore Upright Freezer. Worked fine. Parents moved to an assisted living apt in Jan 2012. Freezer was unplugged and sat for a year. Moved the freezer to my sons garage. The freezer will not get cool or cold.
1. Compressor appears to run.
2. Temperature Control Switch seems to work.
3. Took of panel that covers the evaporator, fan and defrost heater.
4. The very thin copper tubing that comes from the dryer gets cold and will build up frost at the point where the copper tube gets larger, just before it enters the Evaporator. The evaporator does not get cool nor cold.
5. No other copper tubing gets cool or cold.
What the most likely cause of the problem ... low on refrigerant? 134-A. Any parts I should test with my volt ohm meter? What is the most likely cause of the problem? What parts should I test?
thanks for your help
Related Models
Frigidaire 2530A GAS RANGE
Frigidaire 2530B GAS RANGE
Frigidaire 2530C GAS RANGE
Frigidaire 2530D GAS RANGE
Frigidaire 2530E GAS RANGE
Kenmore 25310301000 CHEST FREEZER
Kenmore 25310301001 CHEST FREEZER
Kenmore 25310311000 CHEST FREEZER
Kenmore 25310311001 CHEST FREEZER
Kenmore 25310311002 FREEZER
Kenmore 25310911990 FREEZER
Kenmore 25310911991 CHEST FREEZER
Kenmore 25310911992 CHEST FREEZER
Kenmore 25311301100 FREEZER
Kenmore 25311301101 FREEZER
Kenmore 25311311100 CHEST FREEZER
Kenmore 25311312100 FREEZER
Kenmore 25311312101 FREEZER
Kenmore 25311312102 SEARS/FREEZER
Kenmore 25311321100 CHEST FREEZER
Kenmore 25311321101 FREEZER
Kenmore 25311351100 FREEZER
Kenmore 25311351101 CHEST FREEZER
Kenmore 25311351102 FREEZER
Kenmore 25311511100 CHEST FREEZER
Kenmore 25311511101 FREEZER
Kenmore 25311521100 FREEZER
Kenmore 25311521102 CHEST FREEZER
Kenmore 25311521103 FREEZER
Kenmore 25311531100 FREEZER
Kenmore 25311531101 FREEZER
Kenmore 25311531102 FREEZER
Kenmore 25311531103 FREEZER
Kenmore 25311541100 CHEST FREEZER
Kenmore 25311541102 FREEZER
Kenmore 25311711100 FREEZER
Kenmore 25311711101 CHEST FREEZER
Kenmore 25311711102 FREEZER
Kenmore 25311821100 FREEZER
Kenmore 25311821101 FREEZER
Kenmore 25311911100 FREEZER
Kenmore 25311911101 FREEZER
Kenmore 25312021100 FREEZER
Kenmore 25312021101 FREEZER
Kenmore 25312021102 FREEZER
Kenmore 25312541100 FREEZER
Kenmore 25312541102 SEARS/FREEZER
Kenmore 25312551100 FREEZER
Kenmore 25313009100 FREEZER
Kenmore 25313051100 FREEZER
Kenmore 25313051101 FREEZER
Kenmore 25313051102 FREEZER
Kenmore 25313051103 FREEZER
Kenmore 25313312101 FREEZER
Kenmore 25313351100 FREEZER
Kenmore 25313500100 FREEZER
Kenmore 25313500101 FREEZER
Kenmore 25313500102 FREEZER
Kenmore 25313500103 FREEZER
Kenmore 25313511100 CHEST FREEZER
Kenmore 25313511101 FREEZER
Kenmore 25313511102 FREEZER
Kenmore 25313541101 FREEZER
Kenmore 25313541102 FREEZER
Kenmore 25313551100 FREEZER
Kenmore 25313551101 FREEZER
Kenmore 25313711100 FREEZER
Kenmore 25313711101 FREEZER
Kenmore 25313711102 FREEZER
Kenmore 25313712100 FREEZER
Kenmore 25313712101 FREEZER
Kenmore 25313911100 FREEZER
Kenmore 25313911101 FREEZER
Kenmore 25313911102 FREEZER
Kenmore 25314092101 FREEZER
Kenmore 25314092102 FREEZER
Kenmore 25314092103 FREEZER
Kenmore 25314342100 FREEZER
Kenmore 25314342101 FREEZER
Kenmore 25314342102 FREEZER
Kenmore 25314352100 FREEZER
Kenmore 25314352101 FREEZER
Kenmore 25314352102 FREEZER
Kenmore 25314502100 FREEZER
Kenmore 25314502101 FREEZER
Kenmore 25314502102 FREEZER
Kenmore 25314502103 FREEZER
Kenmore 25314502104 FREEZER
Kenmore 25314502105 FREEZER
Kenmore 25314512100 FREEZER
Kenmore 25314512101 FREEZER
Kenmore 25314512102 FREEZER
Kenmore 25314512103 FREEZER
Kenmore 25314512104 FREEZER
Kenmore 25314542100 FREEZER
Kenmore 25314542101 FREEZER
Kenmore 25314542102 FREEZER
Kenmore 25314542103 FREEZER
Kenmore 25314542104 FREEZER
Kenmore 25314542105 FREEZER
Kenmore 25314552100 FREEZER
Kenmore 25314552101 FREEZER
Kenmore 25314552102 FREEZER
Kenmore 25314582100 FREEZER
Kenmore 25314592100 FREEZER
Kenmore 25314592101 FREEZER
Kenmore 25314592102 FREEZER
Kenmore 25314702100 FREEZER
Kenmore 25314702101 FREEZER
Kenmore 25314702102 FREEZER
Kenmore 25314702103 FREEZER
Kenmore 25314702104 FREEZER
Kenmore 25314712100 FREEZER
Kenmore 25314712101 FREEZER
Kenmore 25314712102 FREEZER
Kenmore 25314712103 FREEZER
Kenmore 25314772100 FREEZER
Kenmore 25314772101 FREEZER
Kenmore 25314772102 FREEZER
Kenmore 25314772103 FREEZER
  #2 (permalink)
Old 06-15-2013, 06:31 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
If the cap tube is only frozen in the evaporator area, use a hot cloth to unfreeze the line. If the evaporator now frosts over, you have moisture in the system. Dryer would have to be replaced and the leak fixed as it sucked in moist air from an evaporator leak. If no frost, your fridg has run out of refrigerant, or the cap line has a restriction.
It has been my experience that a R134A compressor will become inefficient due to operation into a brick wall (frozen capillary). Probably not worth fixing.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Upright Freezer not Cold jjvvww Refrigerator & Freezer Repair 0 07-24-2012 07:11 PM
Kenmore Upright Fridge/Freezer - Freezer not cold enough gstump Refrigerator & Freezer Repair 6 06-13-2012 01:51 PM
Upright freezer won't cool/freeze jasmtnljj Refrigerator & Freezer Repair 4 04-20-2012 12:32 PM
Upright Freezer Won't Get Cold eviscia Refrigerator & Freezer Repair 1 12-31-2011 05:59 AM
Refrigerator warm(not cool) freezer cool (not cold) Magnum777 Refrigerator & Freezer Repair 3 12-24-2011 03:40 PM
